Author Topic: Skid plates  (Read 36047 times)
Offline Pricecheck
Skid plates
« Reply #30 on: February 04, 2014, 02:06:35 PM »
[MENTION=219]Hawaiiysr[/MENTION]  Do you know of a way to inject color into the hope or uhmw?  I'm really wanting to make a design on it.
I know this isn't the same material but I think I might experiment with a cheap dollar store cutting board and fit color dye and maybe some hot glue.  I just don't want the masking material to allow it to bleed too much.
http://www.youtube.com/watch?v=Nanowe1tG9g
Update:  I went to walmart and bought a cheap cutting board, a brush and dye.  I've got acetone here.  I tried rit by itself.  Wiped away with no luck.  Mixed acetone and the same.  I just mixed it about 50:50 (rit dye:acetone) and it's very diluted.  I'll let it set for about 15 minutes to see if I can get any type of stain out of it.  So far this stuff is impenetrable.
« Last Edit: February 04, 2014, 04:54:36 PM by Pricecheck »
Offline Piney0
Skid plates
« Reply #31 on: February 05, 2014, 01:18:28 AM »
I've been researching this some more.  Defanitely going with the GT Thunder skid plate.
I got jealous of the seamless fitment of those conduit straps that are on sameltoe's bike that I started looking for a solution to a square tube frame. I found some moose racing replacement hardware clamps for their skid plates.  Looks like it would be perfect when I find what size i need.
http://www.mooseracing.com/products/?productGroupId=1150&productId=114451
Skid plates
« Reply #32 on: February 05, 2014, 10:12:08 AM »
Nice find Piney0! You could always rubber dip those also to keep from maring up a freshly coated frame...
Skid plates
« Reply #33 on: February 05, 2014, 11:10:00 AM »
Quote from: Pricecheck;24699
I don't think you can dye this stuff. Its food grade so its designed not to stain. Best idea I can come up with is a inlay of different a different color plastic. You can use a router to cut a design then inlay your different color plastic.
Offline Pricecheck
Skid plates
« Reply #34 on: February 05, 2014, 04:07:32 PM »
Hawaii, I tried everything to stain it.  It won't take.  I briefly thought about an inlay but strength would be a concern for me.
Skid plates
« Reply #35 on: February 05, 2014, 04:42:15 PM »
Quote from: Pricecheck;24811
put a big sticker on the bottom so when you wheelie others can see it.haha
Offline Pricecheck
Skid plates
« Reply #36 on: February 05, 2014, 06:22:18 PM »
Ha!  That's probably the only way I can see it working.  Unfortunately that'll be worn away quickly.  I hate being defeated.  I'll find a way somehow.
Skid plates
« Reply #37 on: February 05, 2014, 11:45:51 PM »
I'll brain storm...
Offline brewer_brewer
Skid plates
« Reply #38 on: February 06, 2014, 01:42:25 AM »
I 4rdered a sheet of 1/4" 6061 aluminum from metalsdepot.com.  cost about 60 bucks with the clamps and harware.
Offline ytman
Skid plates
« Reply #39 on: February 06, 2014, 07:37:38 PM »
Quote from: brewer_brewer;24878
That's way heavy duty for a belly pan. 3\16" is plenty strong and mucho lighter
Skid plates
« Reply #40 on: February 06, 2014, 09:57:37 PM »
Nice to know I can hit anything and not worry about it
3/16" is a 1/16" thinner, its 6061 its pretty damn light
Re: Skid plates
« Reply #41 on: February 06, 2021, 08:55:40 PM »
Poly skid......
« Last Edit: February 07, 2021, 03:43:41 AM by croat1 »
Offline desertR
Re: Skid plates
« Reply #42 on: February 07, 2021, 12:16:45 AM »
I also used 1/4" aluminum for mine, either 6061 or 7075(I don't remember). I drilled and nut-serted the frame for attachment. It might add some structural strength also. I made it so the PRM bumper goes over it at the front, so it won't catch on anything. The rear also has a step up to protect the back of the frame.
