Author Topic: Alternative Rear brake Caliper??  (Read 71395 times)
Offline pressure262
« Reply #75 on: April 10, 2016, 11:58:00 AM »
Langbolt anything yet with these conversion brackets?
Online Langbolt
« Reply #76 on: April 11, 2016, 09:09:58 AM »
I've been meaning to Take the bracket and design it up in 3-D Autocad and send the file to Jeremy Nelson - Nelson Precision Manufacturing & see if he would be interested in making the brackets that would bolt up to the 250R standard Brake support and allow the CR twin piston brake caliper to be used.....I should have some time soon to do this.....stay tuned.
Offline Pontas
« Reply #77 on: August 03, 2016, 07:47:18 PM »
Quote from: Tbone07;25432
Look no further my friend
450R Rear Caliper - Any Year
450R Brake Stay - Any Year
450R Disc Hub - Any Year
And 450R brake disc of course
2 washers to space out caliper (see picture)
OEM 250R locknut will work
I think the whole operation cost me $125 at the most
Front and rear, do the 450R brakes fit the 250R right away?
Re: Alternative Rear brake Caliper??
« Reply #78 on: March 30, 2018, 06:57:53 AM »
Bumping this up.
I will be trying the YZ caliper as I did back in the day.  I will keep you all posted.
« Reply #79 on: March 30, 2018, 02:42:08 PM »
I got this: https://www.ebay.com/itm/yz125-yz250-front-brake-caliper-yamaha-oem-2005-2018/192455448779?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
this is the same mount as the yz400 caliper on my 250r.  some machining is needed.  FYI; 250r calipers are going for $250-300.  F that.
« Reply #80 on: March 30, 2018, 02:45:12 PM »
I got lucky and picked up a NOS one for 35
« Last Edit: March 30, 2018, 09:57:34 PM by hickwheeler »
« Reply #81 on: April 09, 2018, 12:58:15 PM »
I’m using the full 450r setup with the exhaust spaced over some. Works great and cheap. Also Glenn innovation makes a caliper bracket to use with 450r caliper and rotor without any other mods needed. Something to consider.
http://www.glanninnovations.com/Products.html
« Reply #82 on: April 10, 2018, 06:33:46 AM »
looks like it puts the caliper very far to the rear.  is this true?
« Reply #83 on: April 10, 2018, 07:24:53 AM »
Im using this same setup.  I wish it wasnt rotated towards the back so far.  I am unable to run 1 of my pinch bolts for the rear carrier.  But it is nice having a 450r caliper rolled back.  Just needs to be about 1/2 way between stock and where Glann has it.
« Reply #84 on: April 10, 2018, 09:17:36 AM »
I didn’t think about that Kyle, but that’s a good consideration. I could technically make those brakes if people were really interested. For now, my 450r set up is working well. I just spaced my silencer out so it wouldn’t hit the caliper.
« Reply #85 on: April 10, 2018, 10:24:19 AM »
all that is needed is a new bracket cut on a laser.
I am just slotting the holes on my 250r bracket and clearancing the  yz mount.
« Reply #86 on: April 10, 2018, 10:27:47 AM »
Where is yours located?  Mine is rolled so far back that it wont hit the silencer or anything.
« Reply #87 on: December 21, 2020, 01:22:38 PM »
Old post id like to BUMP. Lots of good info
John, was there any movement on your bracket?
« Last Edit: December 21, 2020, 01:40:06 PM by Hawaiiysr »
« Reply #88 on: December 23, 2020, 01:10:22 PM »
no Josh.  it worked out for many years.
« Reply #89 on: December 23, 2020, 01:31:17 PM »
Morning Jon. I meant Jon Langman. He was in the works with NPM to make a rear caliper mount. I was wondering if he ever got that going
