Author Topic: Alternative Rear brake Caliper??  (Read 70121 times)
Offline consherm1
250r capiper
« Reply #45 on: May 04, 2014, 12:59:42 AM »
Quote from: rk88r;25434
crf 450 caliper works, you just have to oblong one of the holes in the brake stay.
also I forgot, is that crf450 caliper off the front and what year
« Reply #46 on: May 04, 2014, 12:40:47 PM »
It was on the bike when I got it. I took it off an remounted it with fresh pads, rotor, and rotor guard only.
Offline Vroomy
« Reply #47 on: May 16, 2014, 12:10:33 AM »
well i ordered the part #45190-men-006  and is exactly what i already have! so caliper still not even close to fitting, dont understand. now im invested over $200 into this and looks to be useless
Offline trx250scar
« Reply #48 on: May 16, 2014, 06:48:07 AM »
I ended up welding material onto my brake stay so I could use the crf caliper. Also had to grind on the caliper t Oil get the spacing on the rotor correct. I Also wish I hadn't went with this alternative caliper. I think I will try the yz caliper.
« Reply #49 on: May 16, 2014, 12:49:26 PM »
Quote from: Vroomy;34154
Vroomy can you post some pics of the bracket ? What is the Hole spacing Center to Center ? Is it the Bracket that wont bolt up to the caliper mount ? How far is it off ? We'll figure something out for ya! Hate to hear of a brother out $200!!!
Offline Vroomy
« Reply #50 on: May 16, 2014, 09:30:12 PM »
« Reply #51 on: May 16, 2014, 09:50:45 PM »
The Caliper Bracket hole spacing looks a lot closer than this one from RK88R :(
[ATTACH=CONFIG]4974[/ATTACH]
« Reply #52 on: May 16, 2014, 10:04:56 PM »
I'm betting you need Item #13 on this fische - It's from a 2004 Crf450R - Do you know anyone with a 2004 Crf450R ?
http://www.cyclepartsnation.com/oemparts/a/hon/5053f88af870021c54be8a80/front-brake-caliper
Can you return the one you bought and exchange it for Part# 45190-KZ4-J21
If you enter the Part# here http://www.cyclepartsnation.com/oemparts/partsearch/honda  then select the "Where Used" button it will give you all the models that use that bracket.....hopefully that will help.
« Reply #53 on: May 16, 2014, 10:07:52 PM »
Quote from: rk88r;29491
http://www.servicehonda.com/parts/lookup#/Honda/CRF450R_A%2f%2fB_(05)_MOTORCYCLE%2c_JPN%2c_VIN%23_JH2PE053-5M350001_TO_JH2PE053-5M399999/FRONT_BRAKE_CALIPER/CRF450R-05-JPN-A%2f%2fB/2Y14MEB2MEB4F0700AD
#17
Turns out VROOMY already had Part#17.....he needed Part#13.....the one with the greater mounting bolt spacing :(
« Reply #54 on: August 27, 2014, 12:48:25 PM »
Well I pulled the trigger and ordered a '02 Cr250R Front Caliper & Bracket - (45190-KZ4-J21 bracket part#) So I will see for myself what all is involved to adapt this to our bikes. I'll be sure to take lots of pics and do a write up. The Calipers themselves are available on a wide assortment of recent HONDA bikes.....so availability is easy. What I would like to do is design & Fabricate a mounting bracket that will adapt this caliper to the 250R support plate.....Stay tuned!! :)
« Reply #55 on: August 28, 2014, 01:05:40 AM »
I would like you to design & Fabricate a mounting bracket also
Offline ryanowarrior
« Reply #56 on: August 28, 2014, 10:44:11 PM »
Isn't that what the dream brake stay is for? Allow use of the crf caliper?
Laeger Crf
Laeger R
Walsh R
Walsh Crf (in the works)
« Reply #57 on: August 29, 2014, 08:33:33 AM »
looking at this, there is an adapter plate, showing there should be another mounting hole up closer near the bleeder valve (beige circled area), compared to the mounting holes referenced by the red circles. hopefully the other caliper bracket works for you! let us know!
Offline bnau267
« Reply #58 on: August 29, 2014, 09:41:19 PM »
NPM is making a billet brake stay for me.  It will run the trx450 caliper.  He is in the design phase but I already committed to buy 2.  I sent him my r brake stay and he has the 450 caliper so he's on his way.  I'll keep you all posted as he works on this.
Offline trx250scar
« Reply #59 on: August 30, 2014, 07:34:36 AM »
I used a trx450 Blingstar rotor guard and caliper when I did my rear brake swap. Worked very good. No Fab. Just bolt up. Did require a washer between the rotor guard and caliper for proper alignment.
