Author Topic: need help finding a 96-98 YZ250 wiring diagram - going to try to mate to a cr250 ign  (Read 14378 times)
Bummer, thanks for giving it a shot.
Dave, Do you know anyone with a KTM 300XC ? I've always wondered if that CDI would work on our bikes......the wiring harness is less than $50!
Maybe it's not over......yet ?
No I dont know anyone with a KTM CDI, they look to be made by another company than Denso that Honda and yamaha uses.
the modern engines had kokusan cdi. theres alot of bikes 125, 150,200,250,300. i have wiring diagrams for '99-2011 if it helps any
UDONTKNOWME - Can you post a wiring Diagram for a KTM 2010 300XC ? I'm curious to see if it's similar to the Honda.....Thanks
also look into the gas-gas bikes.  im sure the gas-gas quad curve would be comparable.  just a thought.
Quote from: Langbolt;30146
its in pdf. how do you post that ?
You can attach a PDF just like you do when you post an JPG.....hit the reply button....then the GO ADVANCED button....scroll down to manage attachments....:)
I did confirm what many others have said about the 97-99 flywheels NOT working on the 00-01 CDI's
I was almost certain that I had tested a earlier flywheel on the 00-01 cdi's in the past but my mind must be slipping so sorry if I mis-informed anyone in the past!
I have a expensive Gauss meter available to me from work and I will attempt to map out the magnets using my milling machines degreed rotary table to see what is going on with these flywheels since they are physically the same.
But this will be awhile before I get to this project because I have a bunch of stuff going on right now
its the whole manual on cd. so i have to figure out how to post just 1 page
udontknowme,If you have a PDF printer installed (CutePDF is freeware) Just open the file to the page you want and then PRINT just that page as CURRENT PAGE (theres a box you'll need to check) and change the saved file NAME (to Wiring.pdf) ...Voila! ...One page PDF  :)
ill get it figured out soon as i can. i can post normal photos no problem but i dont know anything about this pdf stuff
