Author Topic: brace for rear fender (Maier)  (Read 5553 times)
Offline Vroomy
« on: April 13, 2014, 01:05:23 AM »
hi has anyone here successfully fitted the rear fender support brace to a Maier fender? could you post some pics for me? im having trouble deciding the best place to mount it and dont want to drill holes in the wrong spot!
« Reply #1 on: April 14, 2014, 12:20:01 PM »
Did you get the Brackets ??? :)
There should be a little dimple on the top surface of the fender - That's where the hole goes......but if not.....mount up the brace under the seat.....put the fender on your quad.....then hold the brace with the bracket attached and then mark the hole on the underside of the fender with a marker. Drill the hole and bolt 'er up! Good luck. :)
Offline Vroomy
« Reply #2 on: April 14, 2014, 08:07:40 PM »
thanks guys, got it done
Offline Wes350x
« Reply #3 on: April 17, 2014, 06:18:40 PM »
Mine is a little different, but I'm sure serves the same purpose. This one doesn't put a hole in the fenders to keep them from flexing though.
1988 250R
Offline TRXforever
« Reply #4 on: April 18, 2014, 10:47:57 AM »
Hey Wes, did you custom bend that piece? What is it? I need some rear fender supports of some kind. When I lean back and dig my heels, the fenders press against the rear tires.
Offline Wes350x
« Reply #5 on: April 18, 2014, 11:20:25 AM »
Quote from: TRXforever;31809
It was on the bike when I purchased it but it is definitely not homemade. Ive got some busy days ahead but Ill try and get some better pics soon.
1988 250R
Offline TRXforever
« Reply #6 on: April 18, 2014, 02:48:33 PM »
Look EXACTLY like what I need!
« Reply #7 on: April 18, 2014, 04:49:58 PM »
Brace
« Last Edit: April 19, 2014, 10:58:04 AM by rk88r »
