86' Cylinder
Topic: 86' Cylinder (Read 2985 times)
Nickthompson
86' Cylinder
April 15, 2014, 12:45:37 PM »
86' non ported cylinder. Has stock bore replacement sleeve in it. Cylinder has been sitting for about 4-5 years on the shelf so it has light rusting to the sleeve. The head also has been repaired where coolant inlet is. This cylinder ran perfect when motor was dissassembled due to cases being busted. 100$ shipped
Pumashine
Supporting Member
Total likes: 27
86' Cylinder
April 15, 2014, 12:50:31 PM »
Yes, it has been ported. But I can only tell you its not stock.
Puma 408,
Puma 431,
Pilot 412,
Puma 431,
Mini-tooth 486
Trx450r
Nickthompson
86' Cylinder
April 15, 2014, 01:46:55 PM »
How can you tell? I would like to know for future reference and I don't want to misinform anyone on a listing
Pumashine
Supporting Member
Total likes: 27
86' Cylinder
April 15, 2014, 05:01:56 PM »
All the aluminum to steel mating surfaces have been smoothed. Its called matching. The knife edge you see in middle of the bottom pic above is square on a stock cylinder.
Puma 408,
Puma 431,
Pilot 412,
Puma 431,
Mini-tooth 486
Trx450r
Nickthompson
86' Cylinder
April 15, 2014, 05:22:23 PM »
Thanks for clearing that up! So guys its had some work just not sure what/who did it.
Pumashine
Supporting Member
Total likes: 27
86' Cylinder
April 15, 2014, 06:04:42 PM »
Usually when someone re-sleeves a stock cylinder it most likely means it was a great working cylinder.
Puma 408,
Puma 431,
Pilot 412,
Puma 431,
Mini-tooth 486
Trx450r
Nickthompson
86' Cylinder
April 15, 2014, 08:04:17 PM »
The R it came off of was pretty snappy! Buddy put it together and ran it for about a month then chan snapped and destroyed left case. I got motor in a deal a fews back and this cylinder has sat on a shelf in my barn since then.
Nickthompson
86' Cylinder
April 17, 2014, 02:32:20 PM »
Bump
86' Cylinder
