Author Topic: Laeger protrax spindle intrest?  (Read 10412 times)
Offline ikas
« on: April 24, 2014, 10:49:03 AM »
Hello, i'm "new" on this forum been on it looking since september 2013 and before that on .net
I have the opportunity to get a hold of machining new spindles that is a replica of the Laeger protrax spindle. The spindle will most likely use 7150 aluminium and be machined in a OKUMA multus B300-W.
I live in Sweden and there is a local business that I have been in contact with about doing a run.
If there is interest there is a big opportunity that there will be a run.
I have sent them measurements and will get a price for what I could expect it to cost to produce the spindles. The price I will get is for 1,5,10,15, and 20 pairs.
« Reply #1 on: April 24, 2014, 11:51:00 AM »
Me:)
« Reply #2 on: April 24, 2014, 12:42:57 PM »
I'm interested.. but would need more details before I commit.
Offline 89Longrod
« Reply #3 on: April 24, 2014, 12:55:07 PM »
I would also be interested in having a spare set of spindles but I will wait on some more info.
Offline ryanowarrior
« Reply #4 on: April 24, 2014, 09:32:00 PM »
Quote from: 89Longrod;32303
Same here
Laeger Crf
Laeger R
Walsh R
Walsh Crf (in the works)
« Reply #5 on: April 24, 2014, 11:02:16 PM »
Interested
Offline ikas
« Reply #6 on: April 25, 2014, 02:57:21 PM »
Happy to see theres interest! I will post some info as soon as I hear something from the supplier.
Offline bnau267
« Reply #7 on: April 25, 2014, 09:35:25 PM »
Quote from: ikas;32389
Are you doing the 450 brakes or the 250r.  I'd buy if you go down the 450 path.
« Last Edit: April 26, 2014, 10:44:30 AM by bnau267 »
« Reply #8 on: April 26, 2014, 06:43:51 AM »
Quote from: bnau267;32420
Are you doing the 450 brakes or the 250r.  I'd be interested if you go down the 450 path.
I am also  interested if they use 450 brakes
Offline troybilt
« Reply #9 on: April 26, 2014, 09:09:25 AM »
Count me in as well, I'd might be interested in large quantities myself.
Elsinore 496cc Saber
« Reply #10 on: April 26, 2014, 09:10:03 AM »
Great idea on using 450 brakes.
Offline bnau267
« Reply #11 on: April 26, 2014, 10:48:09 AM »
Quote from: rk88r;32454
Plus you can use the front spindle shafts from Lonestar.
« Reply #12 on: April 26, 2014, 12:45:49 PM »
So i'm guessing Laeger is unwilling or unable to make these anymore? Or are you able to make them at a lower cost than Laeger?
« Reply #13 on: April 26, 2014, 01:04:41 PM »
Quote from: Tbone07;32466
Last time I checked with Scott, maybe 6 months ago, they were still making these.
« Reply #14 on: April 26, 2014, 03:35:05 PM »
I'm assuming ikas can make these cheaper.  this is a Laeger Protrax component price sheet from maybe 3 years ago (prices might be higher now???):
per Laeger: It is a lot cheaper to purchase a complete spindle ($850) instead of the individual parts, but here you go:
Item        Qty Per Spindle   Price   Total Unit Cost
Aluminum Body                                                            1     $425.00   $425.00
T-Pin        1   $200.00   $200.00
Thrust bearing                                                            1   $51.96   $51.96
Lower Bearing                                                            1   $16.13   $16.13
Bearing Collar                                                            1   $7.53            $7.53
Spindle Shaft                                                            1   $100.00   $100.00
Shaft Collar                                                            1   $27.50   $27.50
Dust Seal        1   $4.18    $4.18
Back Plug        1   $5.25    $5.25
LG Zerk Fitting                                                            1   $1.66            $1.66
Mono Ball Kit (Lower)                                                    1   $35.00   $35.00
Mono Ball Kit (Upper)                                                    1   $35.00   $35.00
Snap Ring        2   $1.25    $2.50
SM Zerk        2   $0.98    $1.96
Set Pin        1   $0.5 0   $0.50
Lug Assembly                                                            1        ?               ?         not sure what is considered the lug assembly
Lug Body        1   $100.00   $100.00
Brass Bushings                                                            2   $12.00   $24.00
SM Clevis        1   $100.00   $100.00
Lock Nut        1   $1.75    $1.75
SM Zerk        1   $0.50           $0.50
1/4 x 28 Lug Bolt                                                    2   $1.75    $3.50
1/4" Washers                                                            4   $0.50    $2.00
1/4" Lock Nuts                                                            2   $1.25    $2.50
7/16" Bolt        2   $25.00   $50.00
7/16" Nut        2   $1.50    $3.00
5/8" Bolt        2   $2.50    $5.00
5/8" Nut        2   $1.75           $3.50
total per spindle: $1,209.92 if purchased by individual parts
« Last Edit: April 26, 2014, 06:53:06 PM by croat1 »
