Author Topic: OEM ignition limitations  (Read 2884 times)
Offline PORTED R
« on: June 03, 2014, 01:50:25 AM »
What's the limit on them
How big of a motor can you run them on ?
And still have a good burn
McCoy ProX 350 5mil Duner
« Reply #1 on: June 03, 2014, 08:28:46 AM »
if you keep the gap on the plug closed up to .016-.018 they will fire in any motor even alcohol feed motors but with the bigger motors you get a hard kickback that you do not get with the CR250 ignition, back 10 years ago when the Sabers came out many people tried running them on the stock ignition and as long as it would start they had no problems but many had a sore foot starting them, one guy use to run a piece of titanium plate on the bottom of his boot to keep from hurting his foot :)
« Reply #2 on: June 03, 2014, 09:33:38 AM »
I run one on my 350 Sphynx with no kickback or starting issues at all
Offline PORTED R
« Reply #3 on: June 03, 2014, 09:49:41 AM »
Good info right there
Thanks guys
Also could a weak stator cause a weak spark even after installing a new coil ?
Even if the stator is still working properly
