Author Topic: phrase of the day  (Read 22973 times)
phrase of the day
« on: June 06, 2014, 08:07:13 PM »
harley davison, the most affective way to convert gasoline into noise without the adverse side affect of horsepower  :glee:
phrase of the day
« Reply #1 on: June 06, 2014, 08:26:40 PM »
good one
Offline atvmxr
phrase of the day
« Reply #2 on: June 07, 2014, 02:19:48 PM »
Effective.....
Jus sayin. :victorious:
Offline oldschoolr
phrase of the day
« Reply #3 on: June 07, 2014, 04:10:59 PM »
:lol:That's a good one,  can I use it?
Offline RIDE-RED 350r
phrase of the day
« Reply #4 on: June 07, 2014, 10:16:37 PM »
Nervous as a cat burying his crap in a pen full of pit bulls....
One of my all time favorites: "When a bullet goes through the brain pan of a hog...sometimes he poops a little" - Phil Robertson
phrase of the day
« Reply #5 on: June 25, 2014, 08:19:50 PM »
im stumped how some people even manage to tie their shoes in the morning  :lol:
found this on another site
DRZjunkie96734, on 25 Jun 2014 - 02:24 AM, said:
Manual for my new 2014 300 XC-W says 60:1 and I've never run a 2T with that high of a mix ratio.  I'm a causal to fast trail rider and am using Motul 800 2T oil.  Just want to confirm that 60:1 is safe before I mix my first tank of fuel for break-in.
Thanks!
some dude responded with this
It will be plenty safe, trust me.  I've run 80:1 before, but be sure to use a quality synthetic oil (Motul, Silkolene, Amsoil).  The oil quality has gotten so good that the age old 32:1 is senseless and wasteful.
Offline Maxxh2o
phrase of the day
« Reply #6 on: June 25, 2014, 11:05:38 PM »
"------- is as useless as balls on a dildo"
Offline atvmxr
phrase of the day
« Reply #7 on: June 25, 2014, 11:19:27 PM »
Quote from: udontknowme;37600
Thanks!
Explain?   His comment has merit, our tanks say 20:1.  In  the nineties this moved to 32:1 then for some of us 50:1 (belray mc1). Amsoil dominator is rated for 100:1 since early 2000s.  Oil technology has continued to improve
phrase of the day
« Reply #8 on: June 25, 2014, 11:34:13 PM »
since when does qaulity outweigh qauntity (not that i consider amsoil qaulity). that stuff would turn to dust just as castor is getting warmed up. im sure jerry has seen a few burned up rod bearings from amsoil  :biggrin-new:
Offline d-rock
phrase of the day
« Reply #9 on: June 25, 2014, 11:53:00 PM »
It's slicker than cat shit on linoleum. Lol.
phrase of the day
« Reply #10 on: June 26, 2014, 12:03:31 AM »
i dont think coc will even recomend amsoil its that bad  :excitement:
phrase of the day
« Reply #11 on: June 26, 2014, 12:18:13 AM »
i cant stand to read this shit anymore
Thanks!
YES! That is what you are supposed to run. That is what KTM designed the motor to run at. That is what the jetting chart is based on. This is not 1972 and that is not a Hodaka. This is 2014 and that is a KTM.
phrase of the day
« Reply #12 on: June 26, 2014, 08:11:09 AM »
No problems with Amsoil here, and I buy by the gallon :)
My old Amsoil dealer did 3 oil changes on his 00' f150, it had 280k on it last I talked to him, he only used Amsoil oil and filter. 3 oil changes!!!!!!
phrase of the day
« Reply #13 on: June 26, 2014, 08:33:58 AM »
phrase of the day
« Reply #14 on: June 26, 2014, 09:00:28 AM »
Quote from: atvmxr;37614
I agree with you. The comment has merit. Also, just to clear up some accuracy, Dominator is rated for 50:1, Saber Pro is rated for 100:1.
Quote from: udontknowme;37615
FYI, Amsoil withstands up to the the temperature needs of the engine and then burns away CLEANLY. Castor does not. Need an example? Glad you asked. I just had a customer that switched from Castor to Dominator. Why? Glad you asked. His son has a 50cc 2 stroke dirt bike that he races. They have used nothing but castor oil since they got it because his dad used to run castor oil years ago in his 250r. But his son has been complaining lately about the engine not running real strong. His dad went back through the engine to find the issue. Turns out the exhaust pipe was almost completely closed off from carbon buildup. That's your "just getting warmed up". I don't really care what anyone says they have seen unless they have some scientific testing to back it up. Otherwise, they are just guessing as to causes. A good oil formula is a blend of all favored characteristics, not just one. If Amsoil doesn't have as high of a flash point as castor oil, then it was designed to be that way on purpose.
And it's not really a quality vs quantity situation, it's concentration vs quantity. You use concentrations in everyday life. Why does it seem so strange here? If you buy some Roundup concentrate and it says mix it 10:1. Do you turn around and say," nope, I'm gonna mix it 2:1 cause that will work better."If it kills weeds at 10:1, then mix it 10:1. Why waste the product and use more than you need? Same for a degreaser like Super Clean for example. If you want to clean engine parts and the instructions say dilute it to 5:1 to clean engine parts. Do then again ignore the instructions, mix it 2:1, and waste the product even though it is designed to be used at 5:1 to do that particular job?  And just one last tidbit, even Maxima Castor oil has ratio recommendations in the 40:1 range up to 60:1.
Quote from: udontknowme;37619
I really don't know why your funny thread, which started well I might add, has turned into an Amsoil bashing thread. I think you will find there are more on this forum that run it than you realize. For whatever reason you don't like it. Fine. Move on. Why ruin a good idea for a funny thread?
« Last Edit: June 26, 2014, 09:21:16 AM by rablack21 »
