Author Topic: Counter Balancer Timing  (Read 3943 times)
Offline The_Steve_Man
« on: June 10, 2014, 10:58:45 AM »
What kind of problems does the counter balancer being out of time cause? Other than vibrations.
« Reply #1 on: June 10, 2014, 11:30:49 AM »
None that I can think of other than vibrations. Maybe rattle some nuts and bolts loose over time
« Reply #2 on: June 10, 2014, 12:12:02 PM »
The vibrations will severe all motor mounts. Don't you think they put a timing mark on it for a reason?
« Reply #3 on: June 10, 2014, 12:31:44 PM »
Is there any other marks you need to line up besides the counter balancer marks and the one on the gear next to it? I just lined those to up...but wonder if there was anymore.
« Reply #4 on: June 10, 2014, 12:46:39 PM »
There is one on the crank and crank gear.
« Reply #5 on: June 10, 2014, 01:27:57 PM »
Quote from: The_Steve_Man;36235
I think the hotrod cranks don't have a mark at TDC like OEM to line up with the crank gear
« Reply #6 on: June 10, 2014, 01:42:52 PM »
Quote from: Pumashine;36238
Surprisingly....mine did have a timing mark.
Get the piston at TDC and line up the dots on the gears and you're done
« Reply #7 on: June 10, 2014, 02:30:26 PM »
Dang it...I need to take my cover back off :-/
