Author Topic: My 353R weight  (Read 8282 times)
Offline Pricecheck
My 353R weight
« on: July 16, 2014, 06:15:12 PM »
Today I finally drove down to the weigh station and got the R weighed.  It's full of fluids and had a couple of extras.  I'll post as such as I can to give you guys an idea on what it weighs.
1986 stock frame with no gusseting.  Refabbed front upper shock mounts.
AC front bumper
AC Nerfs
Eyeball Engineering +2 steering stem
Stock Stem clamp
CCP Stabilizer
Precision Shock and Vibe clamps
Fatbars
Stock throttle
ASV Pro shorty levers
Motion Pro +2 clutch and throttle cable
Extra clutch cable in line with other clutch cable (spare)
ODI Rogue grips
Pro Design Kill Switch Tether
Stock front brake calipers and rotors
Streamline steel braided front brake lines
Stock front spindles
LSR Billet front hubs
LSR +3+1 DC4 LT A-Arms
LSR +3 tierods w/ stock heim joints
Fox Evol Float front shocks
PWK Radiator
Aluminum Shrouds
ESR inline thermostat
ZPC red radiator hoses
Clarke fuel tank w/ cap
Maier race cut plastics with rear heel area trimmed a few inches
N-Style Gripper seat
Stock bottom end with ESR 330 kit bored to 77mm x 76mm stroke with hot rods crank
01 CR250 Ignition
Hinson Counter balancer retaining cap
Sunstar steel 13 tooth front sprocket
Aluminum case saver
ESR TRX5 Pipe with standard mount silencer (recently packed)
Keihin 39mm PWK Carb w/ factory boots
Stock shifter
Stock Kick Start
Stock rear brake lever
TRX450 GT Thunder poly skid (trimmed to fit) using AC full skid mounting hardware
Factory lidless air box w/ K&N filter and outerwears cover
Elka Stage 3 Rear shock
Houser -1 steel swing arm
Stock 86 linkage
AC swingarm skid (minor trimming)
Stock rear brake reservoir
Stock rear brake caliper
Stock rear brake rotor
Stock rear brake hose
LSR Anti Fade Nut
RPM Dominator II +1+4 axle w/ race hub
Sunstar 36 tooth steel rear sprocket
DID 92 Link gold chain
TM Designs chain roller
Stock rear hubs
Hiper Tech3 4-1 10" front wheels
22" GBC XC Master front tires
Hiper Tech3 3-5 9" rear wheels
20" GBC XC Master rear tires
AC grab bar
Billet flag holder
Tool pouch attached to front bumper (5lbs)
This weighed in at 400lbs even.  The guys there said the scale gets down to the pound for you.  I thought it weighed less but once the bigger motor parts, fluids and heavier tires/wheels go on; I guess it adds up.
In case any are wondering what fluids I have so you can compare for some "anal retentive" reason; I'm running VP C12 32:1 w/ Castor 927, Honda HP Trans Oil for the gears, 50/50 Mix anti-freeze, teflon chain saver lube and DOT 4 brake fluid.
Motor mount bolts are stock.  Rear suspension linkage bolts are stock.  Front suspension bolts are Grade 8.  Brake rotor bolts are stock.  All other bolts that I can think of are stainless hex head.
Offline Pricecheck
My 353R weight
« Reply #1 on: August 23, 2014, 04:39:01 PM »
Now I don't know how accurate the certified scales are. My quad was exactly 400. I weighed my truck and trailer and it was exactly 8100. I highly doubt these are to the pound even though the idiots at the counter says you can stand on it and it'll give you your exact weight.  I'm gonna hang it from a large scale after I move.
My 353R weight
« Reply #2 on: August 23, 2014, 04:45:50 PM »
i weighed my 400ex/250r and full of fluids it was 135 lbs.
Offline Pricecheck
My 353R weight
« Reply #3 on: August 23, 2014, 04:46:45 PM »
135 isn't possible. I think there's a typo.
My 353R weight
« Reply #4 on: August 23, 2014, 05:57:59 PM »
Quote from: Pricecheck;41626
how is it not possible?
Offline Pricecheck
My 353R weight
« Reply #5 on: August 23, 2014, 06:01:39 PM »
135 lbs when a 250r motor weighs 65 and the frame and everything else added builds weight. Is it a drag design?
My 353R weight
« Reply #6 on: August 23, 2014, 06:11:46 PM »
Quote from: Pricecheck;41634
that was a typo.  i apologize.
Offline Dirt man
My 353R weight
« Reply #7 on: August 23, 2014, 08:10:38 PM »
I do excavating for a living and drive large trucks over scales regularly, if you are on a scale you can drive a vehicle on, this scales are accurate to 20 lb increments. It rounds up or down  to the nearest 20 increment.
It goes fast over bumps too!
Offline Pricecheck
My 353R weight
« Reply #8 on: August 23, 2014, 09:08:31 PM »
Oh okay. It just sucked that their confidence and description made it sound like it was to the pound.
I'm still going to track down a precise scale device.
Dirt man, thanks for that info though.
Offline Bio86
My 353R weight
« Reply #9 on: August 24, 2014, 03:55:16 PM »
Awesome looking bike though!
McCoy\'d
Offline Pricecheck
My 353R weight
« Reply #10 on: August 24, 2014, 03:57:00 PM »
Thanks bio
Offline The_Steve_Man
My 353R weight
« Reply #11 on: August 24, 2014, 08:54:54 PM »
Metal recycling places have scales that get to the pound.
Offline Pricecheck
My 353R weight
« Reply #12 on: August 24, 2014, 08:56:51 PM »
Very true. I'll pay a few bucks for that! Great advice.
Offline jadleybray
My 353R weight
« Reply #13 on: August 25, 2014, 06:56:21 PM »
bathroom scale will work fine, set bucket/bike stand on scale, set bike on top.  Subtract bucket/stand weight and your set.  Or....
Offline Pricecheck
My 353R weight
« Reply #14 on: August 25, 2014, 06:59:36 PM »
Damn thats light. I'm not sure if my scale will support that much. It's packed up anyways.
