Author Topic: WTB adjustable rear linkage  (Read 5679 times)
Offline steelreign
« on: July 29, 2014, 12:01:38 PM »
Anybody have one they are willing to part with? Thanks
Offline sanddad21
« Reply #1 on: July 29, 2014, 12:17:54 PM »
PM sent
« Reply #2 on: July 30, 2014, 09:15:04 AM »
take the stock dog bone, cut it in the middle and thread the ends, put threaded rod and a couple nuts in it, good to go! cheap route
Offline The_Steve_Man
« Reply #3 on: July 30, 2014, 11:12:42 AM »
I cut a stock dogbone and used square tube to extend it. I have 2 holes on the bottom so I can raise and lower it
Offline steelreign
« Reply #4 on: July 30, 2014, 01:53:05 PM »
Could you post a picture of that Steve? Thank you.
« Reply #5 on: July 30, 2014, 02:26:51 PM »
I can't find a pic but I can take some pics of a spare to show you how I did it
« Reply #6 on: July 30, 2014, 02:37:01 PM »
The dots are roughly where I drilled for a 10mm bolt. I used 5" long tube and lengthened it by an inch. That is plenty for me and I have a second hole to raise it. Works perfect for me.
Offline steelreign
« Reply #7 on: July 30, 2014, 06:58:28 PM »
Thanks Steve. How did you connect the two pieces (weld)?
Offline steelreign
« Reply #8 on: July 30, 2014, 07:00:59 PM »
Oh I think I see. Did you cut it in two and then bolt the metal tubing in the middle? Thanks.
« Reply #9 on: July 30, 2014, 07:03:00 PM »
I didn't.  That is what the square tubing is for. I slid it over each end after I cut it in half. Drilled a hole through the tube and dogbone after I had an inch space. I will post a pic of mine on the bike
« Reply #10 on: July 30, 2014, 07:24:38 PM »
You can see the other that I use to raise it. With 16" tires it sits 7 inches to the bottom of the skid plate. That is only extended 1"
Offline steelreign
« Reply #11 on: July 31, 2014, 07:57:13 AM »
Got it. Thank you so much for all your help.
