Author Topic: Left crank seal installation tool?  (Read 4612 times)
« on: August 07, 2014, 11:33:07 AM »
What do you guys use to install the left crank seal if the engine is still together? You can't use a regular socket the same size as the crank seal as it will not clear the crank shaft. I thought i would ask before going and making a tool.
« Reply #1 on: August 07, 2014, 11:45:18 AM »
Pvc?
Offline Bowtie316
« Reply #2 on: August 07, 2014, 12:02:22 PM »
That one didn't take too much effort to install last time I did one.  I just pushed it most of the way with my fingers and tapped it in lightly with a brass punch. It is supposed to be installed 1/4" past flush with the case.
« Reply #3 on: August 07, 2014, 12:29:26 PM »
Quote from: Bowtie316;40516
I considered this approach as well. Did you freeze the seal first to shrink it or no?
Offline Bowtie316
« Reply #4 on: August 07, 2014, 12:46:39 PM »
Quote from: rablack21;40517
I didn't have to.  It was a hot rods seal so that could have made a difference.
« Reply #5 on: August 07, 2014, 01:26:27 PM »
I always install mine prior to installing the crank. I get it on there flush with the case(using heat + freezing + big socket). Then let the stator push it in the rest of the way
Also, the Tusk crank puller I use can push the seal flush, if I didn't feel like using a socket
Offline Bowtie316
« Reply #6 on: August 07, 2014, 01:56:44 PM »
Quote from: Tbone07;40521
I would be concerned with the stator rubbing on the seal with that method.
Offline mennis1971
« Reply #7 on: August 08, 2014, 07:29:12 AM »
I always put mine in flush and let the stator  push it in the rest of the way. The oem stator backing plate has 3 "fingers" that will seat it for you. IDK abt a cr250 ign tho.
Offline Bowtie316
« Reply #8 on: August 08, 2014, 08:06:22 AM »
Ok, I was thinking flywheel (spinning) not stator (stationary).  I just did what the manual said and installed it 1/4" deep.  I can see now how either method would be fine.
That is probably why the seal can fit somewhat loose in the case, because the stator holds it in.
