Author Topic: Aluminum Airbox Mounts  (Read 3045 times)
Offline ytman
« on: September 21, 2014, 09:28:40 PM »
I ripped this idea off from Troybilt. I saw that he used brake line clamps to mount the front of his airbox. I didn't see how they were mounted to the box though. The problem is the frame rails aren't perpendicular to the front of the box so I couldn't bolt them directly to the box. I got some Alba clamps that have a 1"hole and use rubber to size down to 3/4". I got some 3/8" diam rod and welded it to the airbox sticking out parallel with the frame rails. I had to drill out the small hole in the clamps. Now the front of the box is rubber mounted. The rear mount has always been rubber. I hope it holds. The crappy little clamps I had on there broke every time.
I'll let you know if it works
« Reply #1 on: September 21, 2014, 09:51:03 PM »
are you running the oem snorkel tubes on that set up?  reason I ask...I have never seen an aluminum air box (mass produced) with the snorkel tube cutout.
Offline ytman
« Reply #2 on: September 21, 2014, 10:15:25 PM »
Quote from: croat1;43169
 No Sir. I'm not sure why Timmy Boy put that tube in there when the top of the unit is wide open but I had him make two and they were same same.
