Author Topic: Kill switch and headlight wiring mess...Need help!!!  (Read 10907 times)
Offline DnB_Racing
« Reply #15 on: October 03, 2014, 02:03:56 PM »
the regulator is only for auxiliary circuits (lights) it has no effect on the coil and can be left in the harness and plugged into when you want to use lights by just simply unplug the connector at the stock light switch location in harness and use the yellow wire to feed a toggle or any switching means and run lights as long as they are not above around 65 to 70 watts...
but yes it would be good to insulate the live end when not in use
in the stock stator you can see there are 2 distinctly different sets of windings one set for the cdi to coil for high voltage  spark,, and the others are for lights and what ever you want to setup if clever ...but 2 separate sources completely  ...  you can just about fry your stator lighting coils and still not change the way the quad runs
« Reply #16 on: October 04, 2014, 09:45:00 AM »
Quote from: DnB_Racing;43796
Good to know! Thanks for the info....I HATE electrical problems.....little gremlins that you can't SEE!
« Reply #17 on: December 29, 2014, 03:59:22 PM »
Thank you guys for this info, I was just about to ask this same question.
Can you just fill the removed connections from the CDI box with silicone?
