Author Topic: New Intake/Airbox from ROBL Engineering.......Would you be interested???  (Read 9680 times)
Im not sure if any of you have checked out TroyBilt's airbox/intake boot designs but they are looking amazing.  The flow increases he is showing with a flow bench are astounding. I asked him about a 250R design and he had mentioned that there didnt seem to be enough interest.  So I was hoping that maybe he was misinformed.
We need a better high flowing intake and airbox option.  I know i would want one for my XC bike for sure.  My MX bike would require a different boot due to the cr 500 linkage.
Getting rid of the restrictive rubber boot would be amazing, i think it would also making mounting carbs easier, as you would be able to force them onto the carb from the airbox side instead of having the rubber boot just collapse.
So who all would be interested in a new airbox/boot.  I imagine its going to cost something.  Im sure more than $200, so keep that in mind if you say that you want one.
Lets make this a reality for the 250r brethren.
« Reply #1 on: November 14, 2014, 08:57:50 AM »
I would most definitely be interested in one for my Laeger no-link. My air-box setup is terrible
« Reply #2 on: November 14, 2014, 09:03:12 AM »
Im assuiming he would start by building one for an OEM frame/suspension setup.
« Reply #3 on: November 14, 2014, 09:21:58 AM »
I would definitely be interested in one as long as it is easier to put the carb on instead of more difficult.
« Reply #4 on: November 14, 2014, 10:32:56 AM »
We will need at least 15 confirmed id say to make Robl Engineering interested.
« Reply #5 on: November 14, 2014, 10:35:56 AM »
Kyle, you should post some of the pics that he has done for the 450s. I looked at a couple of the pics. They looked good.
Offline Victork
« Reply #6 on: November 14, 2014, 05:40:47 PM »
Ill buy one as long as its not harder to squeeze my 40.5 pwk in
Offline Victork
« Reply #7 on: November 14, 2014, 05:59:47 PM »
Second thought, ill take one even if its hard to get the carb on lol
« Reply #8 on: November 14, 2014, 06:50:22 PM »
He has a Face book page, with flow bench numbers/video.  Check it out.
« Reply #9 on: November 14, 2014, 07:32:41 PM »
I'm in if it fits cr5 linkage.
« Reply #10 on: November 17, 2014, 07:19:47 PM »
bump it up... Search Robl Engineering on facebook.
« Reply #11 on: November 18, 2014, 11:52:22 AM »
Troy says he has started working on one that will fit the OEM and CR500 frames.
Offline Flyin_250r
« Reply #12 on: November 18, 2014, 12:46:09 PM »
Wish someone closer to him could get him a lobo chassis to make one for it!  I know a few roll owners would be all over them.
Offline Allison#51
« Reply #13 on: November 18, 2014, 10:17:20 PM »
I'm very interested for one on my stock frame. I would imagine the big issue with producing something like that for us is there's just so many different combinations of frames, carbs, and cylinders so i don't know if one universal setup would work for everyone. Obviously the no links would have to be different. I would be willing to make something work.. Nothing else that I've put on my quad has been a direct bolt on so I wouldn't be too sad if It didn't fit perfect. I've been having a lot of issues getting my smartcarb mounted up perfect lately.
Offline troybilt
« Reply #14 on: November 19, 2014, 12:57:41 PM »
Can you guys get me a measurement for the inside diameter of the bell housing (intake side) on your carbs and Smart carbs?  Not the outer diameter, I need the intake to match inside so the transition is minimized.  I'll get UPP to make an adaptor boot to go from the intake tube to the carb.  Right now I don't have a carb to use.  The intake design is mostly done.  I'm going to borrow Dan's airbox to get a box drawn up.
Elsinore 496cc Saber
