Author Topic: Laeger trx250r - Phila, PA area  (Read 4949 times)
Offline beobe99
« on: November 15, 2014, 11:07:21 PM »
Sold!!
« Last Edit: November 23, 2014, 04:28:57 PM by beobe99 »
Offline JFMachado
« Reply #1 on: November 16, 2014, 07:15:24 AM »
What motor are you running in it? Cr Ignition?
Offline beobe99
« Reply #2 on: November 16, 2014, 02:57:39 PM »
Quote from: JFMachado;46064
The engine itself is stock w/ new piston / rings (I believe 86 - 87 model?) with stock ignition.
Offline JFMachado
« Reply #3 on: November 20, 2014, 02:38:50 AM »
So you have paperwork for this frame to register it with DMV?
Offline beobe99
« Reply #4 on: November 20, 2014, 08:55:23 AM »
Quote from: JFMachado;46258
I do not, I checked with the PA DMV to see if it was previously registered after buying it, it wasn't. This was relaxing to know that it wasn't in someone Else's name! They told me the LAE 00/00 0000 vins do exist so registering it was just a matter of taking a photo of the vin and attaching it to the new registration paper work. Or, the bike could be taken to the local Police department for conformation of the #'s.
Anyone who's seriously interested, and needs it registered, I would suggest they call their local state DMV prior to purchasing to confirm the process. The Vin #'s are sequenced like "LAE 00/00 0000" (the zero's would be actual numbers) so if you call you could check to see if the sequence is legit and ask if you had one that was never registered what the process would be.
