Author Topic: TRX250R Motor in a TRX450R Chassis  (Read 65760 times)
« Reply #15 on: December 16, 2014, 01:17:55 AM »
Looks cool with the R engine in it. You have some fab skills, nice work:Boobies2:
Offline Iceracer
« Reply #16 on: December 16, 2014, 08:29:22 AM »
I want to say 2-3 weeks But they had a Holiday in there when I ordered mine. They are good Quality for the price. I still need to get it mounted properly I missed the two lower tabs when I told them how I wanted it.  SO just be specific, yours should be simple.
Originally I needed something for a Woods mini Quad a rider of mine was running and I didn't want to spend 200 on the thin OE radiator it came with and also didn't want a cob in a Huge YFZ either, So I drew up the Apex radiator and specked beefier mounts and bosses to mount a Screen on the front. With it being the first one they had done and for a production machine they could market to, they hooked me up. I was very pleased with it never had a radiator issue again and the machine ran cooler to boot.
Offline Langbolt
« Reply #17 on: December 16, 2014, 12:54:05 PM »
Awesome, I read in your TRX150R post that you shortened the 450R size 38mm.....which would work perfectly for this application......If the 250R rad is too wide I may go that route of a custom rad.
It's narrowing down to possibly a Custom Rad or a Custom PIPE.....If the 250R rad works.....the pipe will too!!! :) I need the brackets to hold the front fenders together to know for sure.....hopefully obtaining them soon!
Offline muthahucker
« Reply #18 on: December 17, 2014, 04:58:56 AM »
Anyway you can take the 450R rad to a radiator shop and have it modified?  I think there is still an old school rad shop at Taunton/Simcoe St N in Oshawa right behind the McDonalds there.. Not sure if that rad can be taken apart and maybe made a bit shorter so it would clear the pipe?  Not sure what that would do for overheating though making the rad smaller...
Offline Langbolt
« Reply #19 on: December 17, 2014, 12:44:18 PM »
I was wondering that too...(I know exactly where you mean....they do gas tanks too!).....but I think it's the CORE they would swap out.....so they would cut the Upper and Lower TANK from the rad and weld in a shorter CORE.....might be cheaper to by a custom rad......I'm gonna try the 250R rad....I just have to fabricate the support brackets.....STAY TUNED :)
Offline Langbolt
« Reply #20 on: December 18, 2014, 12:55:22 PM »
Made some more progress....Got the Motor Mounts all welded up.....gonna swap in the real motor and attach the exhaust and start on the Radiator support brackets. :)
« Reply #21 on: December 18, 2014, 02:54:32 PM »
i wish i could tig :(
those look beautiful tho! :)
Offline Langbolt
« Reply #22 on: December 20, 2014, 10:53:03 AM »
Hit another Snag....I guess running the Rear Shock the way Honda had intended is not an Option....It hits the Carb.....So I think turning it 180 degrees is OK ?[ATTACH=CONFIG]7351[/ATTACH][ATTACH=CONFIG]7352[/ATTACH][ATTACH=CONFIG]7353[/ATTACH][ATTACH=CONFIG]7354[/ATTACH]
« Last Edit: December 20, 2014, 11:07:58 AM by Langbolt »
Offline Langbolt
« Reply #23 on: December 20, 2014, 11:19:50 AM »
Mounted the Pipe.....made a hanger and need to fab one at the front and the rear. Looks like I have enough clearance for the Plastics....won't know for sure till I get the Lower rear fender supports. But if not I'll fab ones that will keep the plastic off the pipe and use some insulated heat shield.
« Last Edit: December 20, 2014, 05:25:10 PM by Langbolt »
Offline Langbolt
« Reply #24 on: December 20, 2014, 11:24:29 AM »
Placed the Rad where it should be.....so I can open the CAP.....but the Lower Outlet hits the pipe.....So I think I'll close that one off and weld an elbow to the underside as there is plenty of clearance for that.....then just to Fabricate the Mounts for the Rad.....Got a couple of good Ideas.... The bottom of the Rad is 2-5/8" higher than the stock location :)
« Last Edit: December 20, 2014, 05:14:25 PM by Langbolt »
Offline Langbolt
« Reply #25 on: December 20, 2014, 05:20:54 PM »
Anyone know what goes in this hole in the side of the fender  ? Or What these tabs on the frame are for ? Thanks :)
Offline Langbolt
« Reply #26 on: December 30, 2014, 05:33:03 PM »
Well I got a chance for some Garage Time......so I thought I would kick it 250R style for the Rad supports. I just have the top mounts held on by screws.....till I take the frame to work and get everything welded up. Here's a few pics of what I ended up with. :)
Offline Flyin_250r
« Reply #27 on: December 30, 2014, 10:31:00 PM »
Looks good. An Afco rad would fix the hose routing problem, wouldn't it?
Offline ryanowarrior
« Reply #28 on: December 31, 2014, 12:14:06 AM »
Quote from: Langbolt;47876
Those are for the plastic louver that goes in front of rad
Laeger Crf
Laeger R
Walsh R
Walsh Crf (in the works)
Offline Langbolt
« Reply #29 on: December 31, 2014, 10:37:52 AM »
Quote from: ryanowarrior;48238
Thanks ryanowarrior - I'll have to try and track those louvers down....the price for new is CRAZY! :)
