Author Topic: UPP intake does not fit  (Read 7787 times)
Offline dem3500
« on: January 07, 2015, 11:28:46 AM »
so i bought an UPP manifold labeled for 38mm intake. i have a 38 airstriker and the boot is way too big. i measured the id of the boot at 44mm and the od of my carb is 42mm. (and i did verify the id of the carb is 38mm) i got it off ebay and have been back and fourth with the seller and i get a lot of strange questions so it is obvious to me this guy doesnt know anything about the product. he asked me for my vin so he could verify the year. strange question but in the end he said send it back and he will reference it off another and send me one that fits. so my question is: is this manifold packaged wrong or am i misunderstanding how to pick out the right manifold?
« Reply #1 on: January 07, 2015, 12:47:01 PM »
http://www.uppracing.com/item.php?pid=232&cid=51
The Part# is correct....it is bit large (44mm) for a carb that is 42mm......Was your Carb bored ?
42mm for a 38mm Bore will only leave a 2mm wall ? Something is fishy..... I'm thinking your carb is a 34mm that was bored to a 38mm bore....I'll measure my Stock carb when I get home for comparison.
Offline dem3500
« Reply #2 on: January 07, 2015, 12:57:06 PM »
Yea 2mm wall. Its a carb that came with an ESR 310 kit. I did get it second hand so I should do a double check on the carb pn but I did measure the I'd and the carb is a 38. Doesn't look bored but I'll dig into it more
« Reply #3 on: January 07, 2015, 01:34:35 PM »
That's the UPP part # I used for my 38MM PWK on my recent build. I think the problem might be on the carb side
Offline dem3500
« Reply #4 on: January 07, 2015, 01:37:48 PM »
OK well I'll double check tonight. Although its still possible the intake got packaged wrong cause I really don't think my carb was bored. What I really need is somebody that has the same intake to measure the I'd if they happen to have the carb off there bike
« Reply #5 on: January 07, 2015, 01:53:08 PM »
Mine is off and i'll try to measure it tonight
Offline dem3500
« Reply #6 on: January 07, 2015, 02:03:31 PM »
Very nice of you! Thanks!
Offline fx4pitrone
« Reply #7 on: January 07, 2015, 03:23:49 PM »
I have a new upp 38 mm intake on the way to me... I should have it Friday or Saturday if you still need help....
Offline dem3500
« Reply #8 on: January 07, 2015, 03:56:20 PM »
Well hopefully I'll get it figured out one way or the other. The guy did tell me to send it back and he will find one that fits. But I'd really rather found out what the actual problem is. If its my fault I don't want to do it again lol
Offline bkstoffe
« Reply #9 on: January 07, 2015, 05:31:29 PM »
sometimes  the OD of the carb is been machined to fit the factory boot. I would guess that this is what has been done to the carb you have.
Offline Quick310r
« Reply #10 on: January 07, 2015, 05:32:24 PM »
It sounds like the intake side of your carburetor may have been machine down, Eddie does this from time to time to fit stock intake boots upon request, It wouldn't hurt to compare it to a another 38 airstriker.
Offline dem3500
« Reply #11 on: January 07, 2015, 05:45:53 PM »
Interesting.......OK I'll be home shortly and I'll take more measurements on my carb. Hopefully somebody has another 38 to co.pare to.
Offline dem3500
« Reply #12 on: January 07, 2015, 06:02:22 PM »
I'm gona guess that's what this lip is from. Measured 42.5mm
Offline Quick310r
« Reply #13 on: January 07, 2015, 06:36:09 PM »
Yes it looks like it has been machine down for a stock intake boot....
Offline dem3500
« Reply #14 on: January 07, 2015, 06:44:39 PM »
Well crap. The stock boot was way cheaper! Oh well. Thanks for helping me out guys!
