Author Topic: Where to get rubber boot for Carb?  (Read 7144 times)
Offline countryboy9799
« on: January 30, 2015, 09:14:02 AM »
It looks they they are no longer available from Honda. I need the rubber intake boot before and after the Carb.
Thanks
« Reply #1 on: January 30, 2015, 09:50:20 AM »
What size carb are you running? You can either find a nice used OEM, or buy a UPP intake manifold.
Here's the UPP Intakes: http://www.uppracing.com/index.php?cid=51
You'll have to comb the for sale section to find a good used OEM carb to airbox boot
« Reply #2 on: January 30, 2015, 09:58:17 AM »
Not sure which Carb I am running, I do know its a Keihin so it could be stock. I just took a hair dryer and heated the boot up and it came right off today. Yesterday when it was 20 degrees I could not get the one between the engine off.
« Reply #3 on: January 30, 2015, 10:12:53 AM »
Here is some pics of my throttle slide. If you look its scuffed up in places and also the rubber boot on top has deteriated. I know the rubber boot should be replaced but what do you guys think about the slide?
« Reply #4 on: January 30, 2015, 10:45:59 AM »
Quote from: Tbone07;49563
Thanks for the link, they don't give those away huh? I might just live with it as the rubber is just a little hard.
I took my caliper to my carb and I came up with 1.365 which is about  35MM so I am guessing its a stock 34MM.  The only number I could find is PJ07abaj2.
I cannot get the float to stop with it disassembled. The rubber on the float actually looks good but I will probably replace it. It doesnt look like that brass piece that the float sits in is replaceable, anyone know if it is?
« Reply #5 on: January 31, 2015, 10:38:47 AM »
Anyone have any thoughts on that slide? Is it still usable or are there going to be any problems with it sticking?
« Reply #6 on: January 31, 2015, 10:43:54 AM »
If it was me I'd be worried about it causing a lean condition.
Offline 4WHLr
« Reply #7 on: January 31, 2015, 10:49:10 AM »
I'd replace it for sure.
 If a new carb isn't in the budget, another used slide should come pretty cheap if its the original 34mm.
I may have a spare slide here somewhere you could have. I'll check for you.
If that chrome flakes anymore you can guess where it will go. Not worth taking the chance for that reason or the sticking possibility.
1986 TRX275R PC2000
Offline Jimbo45
« Reply #10 on: January 31, 2015, 11:32:03 PM »
Quote from: Pumashine;49650
The other one can be gotten aftermarket. http://r.search.yahoo.com/_ylt=A0LEVwxVic1UMhsA34RXNyoA;_ylu=X3oDMTE0cTkyNzM1BHNlYwNzcgRwb3MDMTAEY29sbwNiZjEEdnRpZANWSVA1NjRfMQ--/RV=2/RE=1422784982/RO=10/RU=http%3a%2f%2fwww.dcvmx.com%2fxcart%2fproduct.php%3fproductid%3d186130/RK=0/RS=.ueDjFt._cHxxJpy8Bi.KpwcA0U-
I tried to get one of those, and they are out of stock.  The guy that makes them said they will likely be discontinued, since they are very difficult to make.  I ended up getting a pretty nice used OEM one off ebay, after some patient persistence.
« Reply #11 on: January 31, 2015, 11:53:18 PM »
Quote from: Jimbo45;49660
Same here, I always keep an eye out on Ebay and FB. But it would be nice to have a new flexible one. I'm looking into using the suzuki 500 boot which is still available new.
Offline Jimbo45
« Reply #12 on: February 01, 2015, 09:11:07 AM »
Quote from: Pumashine;49662
Nice! Keep us posted on how that works.  Interesting.
« Reply #13 on: February 01, 2015, 10:35:16 AM »
So if my carb measures 1.365 on the intake side that figures out to about 35mm, I would guess it might taper a little bigger and would be smaller where the slide is so is it safe to say its a 34mm stock carb?
« Reply #14 on: February 03, 2015, 12:09:51 PM »
it is stock 34mm pj carb.
also it looks like eddie still has oem boots.
http://www.eddie-sanders-racing.com/product_p/trx%20250r%20intake.htm
