Author Topic: What MODS should i buy first?  (Read 8992 times)
Offline mkp250r
« on: March 10, 2015, 10:06:28 PM »
Just got an 87 250r, it pretty much bone stock expect for a FMF pipe and silencer.
When it comes to bolt on what should i do first?
Heres my thoughts:
1) Nerf Bars
2) Full skid plates (its an AZ bike and I'm bringing it to NY)
3) Rad valve upgrade
4) K&N filter
5) Maybe cr250 ignition
I would love to put +2 a arms and shocks and a +2 axle but i race cars and thats where most my money needs to go this season.
What else could i do that pretty cheap to get some more power out of the motor????
« Reply #1 on: March 10, 2015, 10:13:13 PM »
Sounds like skid plates are a must, what pipe are you running right now? Another good question is your budget?
Offline mkp250r
« Reply #2 on: March 10, 2015, 10:24:07 PM »
Quote from: Skeans1;51317
Skid plates are a must and same with the nerf bars!
Pipe wise, its a FMF Gold series Fatty and a FMF shorty Silencer.
I could see spending $1,000 right now
« Reply #3 on: March 10, 2015, 10:28:39 PM »
Nerf bars are personal preference I've personally never liked them.
How do you like the pipe, you may want a lower end pipe.
Maybe a set of tires to start with.
Offline mkp250r
« Reply #4 on: March 10, 2015, 10:46:10 PM »
bike hasn't arrived yet from AZ so idk how i like the pipe?
Who make a good low end pipe?
Where i ride i need as much low end power as possible
« Reply #5 on: March 10, 2015, 11:01:47 PM »
I would first check the bike over real well. If things are worn out they need to be replaced first. I.E.the airfilter may be shot, if there is no airbox setup I would be putting one on right away. Then I would do.
1) Full skid plates
2) Nerf Bars(with built in pegs)
3) Suspension
4) 38mm Kehin
5) VForce3 Reeds
6) ESR TRX5 pipe
7) CR250 ignition (I have a bike with/and one without, if you plan to ride at night then it is not the setup for you)
I ran a stock cylinder(no porting) and basically the mentioned setup, with a cr ignition. And that little bike flat out rips. I could defiantly out ride my skill level.
Offline mkp250r
« Reply #6 on: March 10, 2015, 11:06:04 PM »
Quote from: Rupp250;51325
1) Full skid plates
3) Suspension
4) 38mm Kehin
5) VForce3 Reeds
6) ESR TRX5 pipe
Thanks man…
« Reply #7 on: March 10, 2015, 11:49:05 PM »
Lrd or LED pipe any work pretty good as well they seem to be a pretty low end and mid pipe.
« Reply #8 on: March 11, 2015, 06:36:19 AM »
If you're riding woods and need low end, vf3 is not probably the best choice. The boyseen rad valve seems to be the choice for that type of riding. I beleive I remember seeing a dyno sheet that proved that, but can't remember where. Other than that, I agree with everything rupp said. Although a trx5 is a great all around pipe, I am sure there's a better low end pipe out there. I run the 5 on my duner and absolutely love it.
« Reply #9 on: March 11, 2015, 09:26:41 AM »
what rupp said, i would pull a arms off, shocks off, swingarm off, and check and replace bushings and bearings as needed throughout.
depends if you want to put your money into chassis mods first, or motor upgrades.
nerfs are personal preference. since you mentioned them first i assume u like them. if you pick them up get good ones with built in pegs.
after that there is endless directions u can go on base chassis upgrades, but most of those will max out your budget so u may want to wait.
fmf is a decent low end pipe to compliment minor bolt on mods. begin with intake tract (carb reeds filter). if you want more mid top end u can upgrade to esr 5 pipe later (best all around pipe).
personally the first thing i would do is cr ignition, but they are hard to find and will eat up most of your budget, so you may want to hold off on that.
Offline mkp250r
« Reply #10 on: March 11, 2015, 11:07:27 AM »
« Reply #11 on: March 11, 2015, 11:24:47 AM »
She's Purdy. Normally it goes pipe, reeds, carb. In your case I might go straight to the suspension if it runs well.
Offline mkp250r
« Reply #12 on: March 11, 2015, 12:06:02 PM »
Is there a recommended big bore kit I can buy that would save me the trouble of piecing everything together and just get the motor done all at once?
And then I could buy a set of used shocks and a +2 axle.
« Reply #13 on: March 11, 2015, 02:24:52 PM »
Offline patman13mia
« Reply #14 on: March 11, 2015, 02:33:39 PM »
Best bang for your buck is gonna be those esr kits!! I think thats a great price for everything in one package!!
