Author Topic: Help! Someone with an '88 or '89 with OEM headlight.......  (Read 4784 times)
Offline Jimbo45
« on: March 14, 2015, 09:05:43 PM »
If someone could please measure the dimension of the headlight mounting collar, inside the washer portion, that would be awesome!  I have all the parts to install my '88 style headlight, but the metal collars are unavailable.  I have some metal tubing and an SS washer, that I intend to fab my own collar, but I need the dimension shown (or the overall length with the washer portion if its easier). Also, not noted on the diagram I made, but the diameter of the barrel portion that fits into the rubber bushing would be nice too!  The part I am referring to, is part #3 on the partzilla link below:
http://www.partzilla.com/parts/search/Honda/ATV/1988/TRX250R+A/FRONT+FENDER+88%2C89/parts.html
« Reply #1 on: March 15, 2015, 01:57:36 AM »
I'll get it for you in the morning
Offline Jimbo45
« Reply #2 on: March 15, 2015, 02:01:34 AM »
Quote from: hickwheeler;51614
Thank you!!!!!!!!!!!!  Also, the diameter of the shaft that fits into the rubber if you can.  Thanks again!  Jim
« Reply #3 on: March 15, 2015, 02:19:04 AM »
went out and got it for you now. my measurements are in mm. shank length 27.5, with washer 29. barrel size 9.5 to 10. They are not a perfectly round piece. Hope this is what you are looking for. If you need more info let me know.
Offline Jimbo45
« Reply #4 on: March 15, 2015, 02:26:41 AM »
Quote from: hickwheeler;51616
Perfect!  Thanks so much!   I owe you one!
« Reply #5 on: March 15, 2015, 02:29:02 AM »
no problem
Offline Jimbo45
« Reply #6 on: March 16, 2015, 02:41:20 PM »
Quote from: hickwheeler;51618
no problem
Thanks again hick wheeler, I found some bronze bushings that are the perfect diameter and length when I add a stainless fender washer to the outside!  Didn't even have to cut them!
« Reply #7 on: March 16, 2015, 02:51:31 PM »
sweet glad I could help
