Author Topic: Water pump impeller compatibility with other models  (Read 24106 times)
« on: April 06, 2015, 10:45:21 AM »
Does anyone know for certain if any other water pump impellers from a cr250 or cr500 will work on a 250R? Has anyone successfully used one? Just curious.
« Reply #1 on: April 06, 2015, 11:11:27 AM »
Perhaps even one from a 4 stroke might work. If that was found to be the case, maybe one of the high flow impellers would work.
« Reply #2 on: April 06, 2015, 02:42:19 PM »
I considered attempting to design a new water pump impeller. One that would flow more than the stock one does now.
« Reply #3 on: April 06, 2015, 05:30:32 PM »
Quote from: rablack21;52731
excellent idea!
John
« Reply #4 on: April 06, 2015, 05:33:08 PM »
I may pursue this idea. I have an extra clutch cover. I may have to enlist the help of others to come up with another water pump shaft and impeller. I would set up a bench test and measure the flow of the stock impeller. Then model up a few different designs and have a friend machine them and then test them.
« Reply #5 on: April 06, 2015, 08:46:13 PM »
Basing it off the 89 would be the easiest because than you could use the 89 shaft & not have to worry about splines. You'd only need to redesign the impeller that way.
« Reply #6 on: April 06, 2015, 09:07:52 PM »
Guys, I need a little help. I need some pics of an 89 impeller, particularly the back side. Broken answered one question for me. 89 has no splines. I need to see if the rest of the back and the inner part look like my 85-88 impeller. I'm gonna start modeling up a new one tomorrow.
« Reply #7 on: April 07, 2015, 07:12:29 AM »
A couple pics of my first idea.
« Reply #8 on: April 07, 2015, 07:13:22 AM »
This one was modeled similar to the fins on Boyesen's super cooler kit.
« Reply #9 on: April 07, 2015, 07:19:16 AM »
here is how dasa made a high flow impeller for a SxS. left is stock, right is high flow
« Reply #10 on: April 07, 2015, 07:28:39 AM »
Thanks for the pic, Jesse.I considered trying something like that as well. Yeah, I believe as you straighten out the fins, you are pushing more volume towards the out port. That pic helps a lot with ideas though. I may consider something like that as well.
« Reply #11 on: April 07, 2015, 07:40:14 AM »
was doing some reading, perhaps the 90 degree elbow at the back of the head is turbulent restrictive spot also. it makes sense.
also, here is a side by side comparison from a yz450f stock impeller vs. its high flow boyesen counterpart. it seems they use the impeller to fully utilize the water pump cavity as much as possible
« Reply #12 on: April 07, 2015, 10:30:58 AM »
I was talking to a local engine builder o e time and he mentioned why not use a cr shaft, but didn't go I to details about it. Maybe I'll swing out there sometime an ask specifically.
« Reply #13 on: April 07, 2015, 10:40:06 AM »
If he knows that a cr shaft would work, that would be very helpful. I personally don't know. If you find out, let me know. Otherwise, I might go out to my local shop and see if he has any cr shafts laying around.
Offline udontknowme
« Reply #14 on: April 07, 2015, 07:27:48 PM »
rumor has it that fast water speed and a smallish cooling system capacity works best. huge volume in the head is no good. seems like kevin cameron has talked about it
