Author Topic: Leaking gas  (Read 3989 times)
Offline Quinnlt4
Leaking gas
« on: July 21, 2013, 10:33:06 PM »
So I went riding and used all my gas. Had to go buy so cheap 2cycle oil from the gas station. Mixed it up and started fouling plugs. Brought my R home. Drained all my gas and put in a new plug and new gas with 927.  Now when I turn the gas on it runs a steady stream out the float bowl overflow tube. I checked my float lvl and its fine. Any ideas as why this is happening?
1986 Laeger wannabe
Offline jamieg45
Leaking gas
« Reply #1 on: July 21, 2013, 11:21:22 PM »
It almost sounds like when you turn the gas on the needle is stuck in the seat and letting it fill and fill.
01 Lsr 250r
00 Walsh 250r
Offline Quinnlt4
Leaking gas
« Reply #2 on: July 21, 2013, 11:30:43 PM »
Yea. I will check that. Thanks
1986 Laeger wannabe
Leaking gas
« Reply #3 on: July 22, 2013, 01:55:44 AM »
I have had this happen  and was able to get it to stop by tapping the bowl with the plastic end of of a screwdriver
Leaking gas
« Reply #4 on: July 22, 2013, 10:54:28 AM »
Sounds like when you ran it out of gas it sucked all the junk from the tank into the carb. Do you have a fuel filter on it?
I would pull the carb and clean it all out.
Offline PORTED R
Leaking gas
« Reply #5 on: July 22, 2013, 06:00:26 PM »
U would be surprised what's in the gas tank
I try to keep mine clean ,especially from sand at the dunes
I just pulled my tank to clean it because I had a loose hose
I found some sand and dirt particles in it
McCoy ProX 350 5mil Duner
