Author Topic: LSR ball joints  (Read 6606 times)
Offline Vroomy
LSR ball joints
« on: July 24, 2013, 09:00:34 AM »
Where's the best place to get replacement ball joints for LSR a-arms?
Online Langbolt
LSR ball joints
« Reply #1 on: July 24, 2013, 01:01:03 PM »
This has All the listings with Thread sizes, tapers etc,etc
So for all those looking for Ball Joints for their Aftermarket A-Arms...look no further!
Eg:Look up ES3045RL ....these are common for some.
http://www.moog-suspension-parts.com/Universal_Outer_Tie_Rod_Ends.asp
Those having difficulty....
http://www.moog-suspension-parts.com/proddetail.asp?prod=MOOG-ES3045RL
« Last Edit: July 25, 2013, 10:19:32 PM by Langbolt »
Offline derby
LSR ball joints
« Reply #2 on: July 24, 2013, 08:35:50 PM »
I just bought a new set and they are a frap brand.
Nothing but a washed up trx250r.net hasbeen.
Offline Vroomy
LSR ball joints
« Reply #3 on: July 25, 2013, 10:33:10 AM »
Those links aren't working, cold just be my computer. Are those ASR heim joints any good?
Online Langbolt
LSR ball joints
« Reply #4 on: July 25, 2013, 10:20:49 PM »
Quote from: Vroomy;5603
Not sure what happened.....I re-copied and pasted and they work now....Update links ;)
Offline Vroomy
LSR ball joints
« Reply #5 on: August 20, 2013, 09:41:11 PM »
Does anyone know if ASR ball joints fit Lonestar arms? I can easily get a set of those posted to me
Offline The Phantom
LSR ball joints
« Reply #6 on: August 20, 2013, 09:55:18 PM »
Quote from: Vroomy;9365
It will depend on the size of your A-arms.  Ive found some are 14mm, 16mm  some only thread in on the lower and not on the upper(like mine) and some also thread in the top A-arm.  ASR appears to be selling these in American sizes.  Mine were 14mm with I believe a 1.5 pitch thread (for A-arms) and 10mm taper nut size.
1988 TRX ESR 350 PV +4 STROKER (363)RACE DOME* ESR TRX9 PORT AND TRX5B PIPE & SILENCER*38mm Smartcarb*V-FORCE 3 REEDS*CR500/400EX CLUTCH MOD*ESR BILLET KICKSTARTER,SHIFTER,BRAKE LEVER, TEMP GAUGE*GPI RADIATOR & HOSES*LSR +2 A-ARMS*LSR STEERING STEM & CLAMP*LSR CARRIER & AXCALIBER AXLE*ITP SS112 RIMS WRAPPED WITH RAZR 2\'S*TRIPLE RATE WORKS FRONT SHOCKS W/REZ*AC RACING NERFS*DG FRONT BUMPER*LED TAILLIGHT
Offline Vroomy
LSR ball joints
« Reply #7 on: August 20, 2013, 10:00:29 PM »
Wow sounds real confusing, I have no way of measuring the pitch. All I know is mine are the older style +3 long travel arms
LSR ball joints
« Reply #8 on: August 21, 2013, 08:03:36 AM »
Vroomy, shoot Jon (Spiritaces) a pm. He is now an LSR dealer. See what he can do for you.
Offline rsss396
LSR ball joints
« Reply #9 on: August 21, 2013, 09:21:35 AM »
Quote from: Vroomy;9369
If you have or know somebody with a tap and die kit they all come with thread pitch gages, they look like a feeler gage with saw teeth, you just match the thread up to the gage that fits, the gage will be marked with the thread pitch.
Everyone should at least have a tap and die kit in their garage if you are working on anything, even the cheap kits from harbor freight have saved me out in the dunes (leave the good kits at home)
LSR ball joints
« Reply #10 on: August 21, 2013, 09:25:29 AM »
Quote from: rsss396;9400
Agreed ^^^. My harbor freight tap and die kit has been worth every penny.
Offline jamieg45
LSR ball joints
« Reply #11 on: August 29, 2013, 11:44:57 AM »
I found moog ball joints for a set of lsr arms I had on one of my banshees, I just can not remember the part number at all.
01 Lsr 250r
00 Walsh 250r
Offline 05450r
LSR ball joints
« Reply #12 on: August 29, 2013, 11:54:41 AM »
So is there a Moog # that will fit 16mm arms?
04 450r XC
Offline jamieg45
LSR ball joints
« Reply #13 on: August 29, 2013, 04:33:24 PM »
I do believe so Eric, I will have to call my buddy up and get the part # off of the boxes. I gave him the old ones in the boxes when he bought the lsr arms a few years back and he saves everything.
01 Lsr 250r
00 Walsh 250r
Offline bholzgen
LSR ball joints
« Reply #14 on: August 29, 2013, 05:33:29 PM »
This is very helpful, thanks guys!
2002 Roll Design Lobo MX
2002 Laegers CRF450R Hybrid
1985 ATC 70
