Author Topic: Seat Nubbins  (Read 6151 times)
Seat Nubbins
« on: August 28, 2015, 05:02:46 PM »
Anyone know where to get these rubber pieces that seem to be better than stock. It has A 29 stamped from the mold. The ones in the front are the ones that were on a frame I bought on ebay. Inner hole is 3/8". Stock are in the rear of pic. A while back guys had a part# you could get at the auto parts store. Thanks in advance
Seat Nubbins
« Reply #1 on: August 28, 2015, 05:20:31 PM »
I have a sears hardware  i went to last time  to pick them up. An a few months  back i sent someone  looking  for them there an they found  them . So should  be able to find  em there tony if ya have a sears  hardware  close  too ya.
Seat Nubbins
« Reply #2 on: August 28, 2015, 06:12:47 PM »
Thanks I can stop there on the way home. I think it was also found as a shock part at Oriely's. This one is solid and will not break or get loose like OEM.
Offline spintly
Seat Nubbins
« Reply #3 on: August 28, 2015, 06:58:40 PM »
Just an FYI.  You can use stock trx450r mounts to relace the front ones.
Seat Nubbins
« Reply #4 on: August 28, 2015, 07:56:28 PM »
Quote from: spintly;57685
I will have to take a look they are a better price than 250r
450r seat nubbin
CUSHION, FR. FUEL TANK 17611-HP1-000 $2.89 from service honda
250r seat nubbin
RUBBER, FR. FUEL TANK 17611-HA5-000  $3.70
Offline maburns
Seat Nubbins
« Reply #5 on: August 28, 2015, 08:38:55 PM »
Would love to know myself. I'm missing about every piece of rubber the R has
Seat Nubbins
« Reply #6 on: August 28, 2015, 11:29:49 PM »
There is a O'Rileys part that works well. Or so I am told. I'll track down the PN and get back to you all.
Online croat1
Seat Nubbins
« Reply #8 on: August 29, 2015, 01:04:38 PM »
Just an FYI.  You can use stock trx450r mounts to replace the front ones.
Thanks for the hint. I checked to see if those were the ones I had found on this frame. They look identical to the 450r nubbins but have a smaller diameter hole instead of the 12mm hole the 450r nubbins have. So the 450's will work perfect but the one with the smaller hole works better on worn out frames missing 1/2 the bar they sit on. 450r nubbin in center
The new ones from TM design look and work totally freaking awesome. Might have to get a set for the new build. You use a C clamp to press them on, those suckers will never come off!
Seat Nubbins
« Reply #9 on: August 29, 2015, 01:38:12 PM »
Here is the part from O'Rileys. Thanks to Dana for the pic.
Seat Nubbins
« Reply #10 on: August 29, 2015, 04:20:11 PM »
http://www.amazon.com/gp/product/B000CN7CGU/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER These are the black ones at amazon
I ordered the 8 of them for $14
« Last Edit: August 29, 2015, 06:14:27 PM by Pumashine »
