Author Topic: Fresh build need help please  (Read 7760 times)
Offline jshady77
« on: September 21, 2015, 09:47:18 PM »
Hey Guys,
Just got the new R fresh rebuild completely, been through heat cycles 1/4 throttle cycles, and now doing 1/2 throttle cycles, did compression test with cheap harbor freight tester fresh out of box and only got 90 psi wot and at least ten kicks, starts perfect everytime first kick, feels better and tighter than my last R that was only 152 psi and that kicker went down super easy on that on. The thing runs beautiful and idles perfect, are these testers accurate for cheapies? Or do you think the rings are not seated, just hoping the job was done right. Any help would be appreciated.
« Reply #1 on: September 21, 2015, 10:29:19 PM »
so was the original owner the one that got 195 compression and now you are getting 90
Offline jshady77
« Reply #2 on: September 21, 2015, 10:32:40 PM »
yes he said he was getting between 185 and 195
Offline jshady77
« Reply #3 on: September 21, 2015, 10:33:22 PM »
would it start and run good with only 90psi??
Offline jshady77
« Reply #4 on: September 21, 2015, 10:35:05 PM »
it was holding at 90 psi and not dropping at all??
Offline jshady77
« Reply #5 on: September 21, 2015, 10:36:51 PM »
it does seem to kick easier with the test kit in, then when I put plug in it feels tighter..
Offline MTech
« Reply #6 on: September 21, 2015, 10:40:54 PM »
Have you tried a little thread tape on the tester to make sure it's sealed? Can't comment on if it would run @90 psi, but I've gotten false readings conducting compression tests because I didn't have a good enough seal.
Champagne taste; beer money pockets.
Offline jshady77
« Reply #7 on: September 21, 2015, 10:54:57 PM »
No have not tried that but I am going to return this one and use the renta tool one I used on my old R that got 152 psi and i know for a fact that one kicked over easier than this one, it just feels like the compression is good with how hard the kick is and it doesnt sound like theres slop when its running, maybe im wrong I am new to these. And definately not a mechanic just a rider lol
« Reply #8 on: September 21, 2015, 10:58:30 PM »
Sounds like u got a junk tester.
Offline jshady77
« Reply #9 on: September 21, 2015, 11:03:39 PM »
Thats what im hoping did a search on google and seen that several other people had the same problem with the same harbor freight tester and got the same 90 psi , they used a different one and blam different results. Im just nervous of this break in period never did one and dont want to mess it up, especiall taking over where someone else started.
« Reply #10 on: September 21, 2015, 11:10:19 PM »
I would also think it is a junk tester.
You have given your rebuild more time then any I have ever done.
Offline jshady77
« Reply #11 on: September 21, 2015, 11:15:38 PM »
Yeah I called the guy and started ripping him but he swore up and down junk tester he did give me all the paperwork for the build, I kinda felt bad, he offered to drive an hr and half to test for me, but I told him no worries Ill get a new tester and go from there, nice guy like I said he was like 60 yrs old.
Offline jshady77
« Reply #12 on: September 21, 2015, 11:37:20 PM »
https://www.youtube.com/watch?v=EN7CvvP59xg&feature=youtu.be
Here it is running right after I brought it home let me know what you think and if this even works, new this lol
Offline jshady77
« Reply #13 on: September 21, 2015, 11:39:16 PM »
sorry its sideways lol
« Reply #14 on: September 21, 2015, 11:56:27 PM »
Says removed
