Author Topic: 370R no link dune build  (Read 47718 times)
Offline SDFab
« Reply #45 on: February 22, 2016, 08:35:26 AM »
Stabilizer and skid plate below. Has a drain built in for the overflow
« Reply #46 on: February 22, 2016, 08:51:29 AM »
Quote from: SDFab;64888
Have a few small updates. Mounted a coolant tank. These are a must have in the desert. The extra capacity won't hurt either.
Very nice who made the tank?
Offline SDFab
« Reply #47 on: February 22, 2016, 12:21:46 PM »
Not sure. Cost $50 from a hot rod shop down the street. Might have been used.
Offline Wrench U
« Reply #48 on: February 22, 2016, 07:48:48 PM »
Nice use of space. I have a question, is that the filler cap for the whole coolant system. Or is it just a overflow reservoir.
Offline SDFab
« Reply #49 on: February 23, 2016, 12:43:34 PM »
Just the reservoir fill cap. Needs a window or something to check the fluid level. Will have to figure that out later.
« Reply #50 on: February 23, 2016, 12:54:59 PM »
Nice work SD. It would have to be an overflow/expansion reservoir seems it's lower than the top of radiator.
Offline SDFab
« Reply #51 on: February 23, 2016, 01:15:04 PM »
Yea. It works from pressure so it doesn't really matter where it's mounted.
Offline Wrench U
« Reply #52 on: February 23, 2016, 06:38:14 PM »
Quote from: rk88r;64931
That's why I asked.
Offline Wrench U
« Reply #53 on: February 23, 2016, 06:42:47 PM »
Quote from: SDFab;64929
Look at go kart stuff they have similar set up. They use a clear hose running vertically with a 90 degree fitting at the bottom and top tapped into reservoir. U can see the fluid level at a quick glance.
Offline SDFab
« Reply #54 on: February 23, 2016, 11:43:01 PM »
Yea I thought of that. Definetly the best option. I guess for now I will just stick my finger in there between rides and make sure it's about 3/4 full. Lol
Offline 88trx
Re: 370R no link dune build
« Reply #55 on: February 27, 2023, 04:22:30 PM »
Did this bike ever get finished?
« Reply #56 on: March 01, 2023, 10:02:58 AM »
I would like to say that it was but the original poster hasn’t been on the forum in 7 years
