Author Topic: 44mm lectron on a 363 sphynx?  (Read 16976 times)
Offline Saber569r
« on: January 04, 2016, 08:52:20 AM »
Maxed out my jetting done at hassy drags, got to a 220 and still felt lean.  Would 44mm lectron be a better set up? I only run the hill and straight drags.
« Reply #1 on: January 04, 2016, 09:02:44 AM »
Quote from: Saber569r;62866
That'd work or run a smart carb on that motor like I did
Offline Saber569r
« Reply #2 on: January 04, 2016, 09:20:45 AM »
Quote from: Skeans1;62867
Been thinking about getting the smart carb but 38 might be too small. Can a smart carb be bored to 40.5? That be the way to go?
« Reply #3 on: January 04, 2016, 09:26:05 AM »
Quote from: Saber569r;62869
I ran a billet 40 with a Q05 rod
https://technologyelevatedco.com/product-category/large-billet-smartcarbs/
« Last Edit: January 04, 2016, 09:47:58 AM by Skeans1 »
« Reply #4 on: January 04, 2016, 10:05:59 AM »
Are you running Alky? What carb do you have now? If on 110 that 220 is huge compared to what my 363 ran. 0Ft of elevation, 40.5mm Kehein, Shearer OOF, VF3 I was running below a 170 main I think.
You run alky through the Smart Carb?
« Reply #5 on: January 04, 2016, 10:16:53 AM »
Quote from: Rupp250;62872
Rupp I did not, this is a 110 motor that Matt told me when I had the pipe built would take a huge jet the volume and length of pipe is huge for an inframe.
Offline Saber569r
« Reply #6 on: January 04, 2016, 10:39:19 AM »
I ran vp 110, 220 main still felt lean but ran great, Its a brand new 40.5 from Eddie.
« Reply #7 on: January 04, 2016, 12:28:44 PM »
Saber, what does the plug look like?
Offline Saber569r
« Reply #8 on: January 04, 2016, 12:44:23 PM »
A littltle white but never ran over 180 degrees.
Offline Piediddy
« Reply #9 on: January 04, 2016, 01:15:11 PM »
If it's just a drag bike I'd run a Lectron. Call Dennis Packard and have him set one up for you with the big bowl
Offline kb250r
« Reply #10 on: January 04, 2016, 06:26:36 PM »
Hills and straight drags...get a Alky dome,call Packard for lectron and put another 20 horses on that bad boy!!!!!����
Atc - 350 6mill
Atc - 350 4mill
Trx - 431 puma
Engineered by C-Leigh Racing
Offline Saber569r
« Reply #11 on: January 04, 2016, 08:25:07 PM »
Quote from: kb250r;62893
Been thinking of having Pete cut me one. Just can't get alky up here. Only place to get is a hour and a half away. Theirs a vp outlet in Phoenix.
« Last Edit: January 04, 2016, 08:46:36 PM by Saber569r »
Offline Morse250r
« Reply #12 on: January 04, 2016, 08:57:31 PM »
Check local race engine shops for cars for alky too. I ran a 44 and a 48 lectron on my pro x on alky
On gas 40.5 and yes 168 and below on the jets shearer pipe
88 rb racing duner
Trx 70\'s
Atc 125
Offline kb250r
« Reply #13 on: January 04, 2016, 10:19:59 PM »
A hide a way spot that people over look is a cart shop or go cart racing shop the keep tons of Alky!!!!
Atc - 350 6mill
Atc - 350 4mill
Trx - 431 puma
« Reply #14 on: January 05, 2016, 12:07:44 AM »
Quote from: Saber569r;62908
There should be some guys in Flagstaff that have sprint cars or midgets that have drums of methanol or can tell you where they get theirs.
