Author Topic: Kick starter  (Read 7025 times)
Offline bill1984
Kick starter
« on: July 29, 2013, 09:15:10 PM »
This my version of dd kicker shaft , much cheaper lol.. I took 2 shafts and  pined the 2 together and welded them.[attach=config]1099[/attach][attach=config]1100[/attach] so far so good. I got  4 weekeds of racing on it..
Offline Polonda
Kick starter
« Reply #1 on: July 29, 2013, 09:17:57 PM »
Nice!  And with a good weld job it will never break.  This is the kind of stuff I'm all about.
Offline Morse250r
Kick starter
« Reply #2 on: July 29, 2013, 09:22:17 PM »
Direct drive used to modify stock kickers and they wod snap over time that's why they had the new lengthed ones made now.  But most have more time then money but as long as it doesn't brake a leg!
88 rb racing duner
Trx 70\'s
Atc 125
Offline atv fan 28
Kick starter
« Reply #3 on: July 29, 2013, 09:22:38 PM »
nice job!!!!
Kick starter
« Reply #4 on: July 30, 2013, 07:56:32 AM »
damn good, cant really see where the weld is.
here is a way to strengthen it:
bore a hole in either end that will allow a press fit
press in a high tensile steel rod
press other end on, then weld that sucker together.  should never break.
Offline bill1984
Kick starter
« Reply #5 on: August 02, 2013, 09:40:25 PM »
Thanks guys
Offline Farmboy1979
Kick starter
« Reply #6 on: August 09, 2013, 07:30:42 PM »
How did you make sure the shafts were straight?
Offline bill1984
Kick starter
« Reply #7 on: August 12, 2013, 10:04:36 PM »
I used my lathe when i drilled the two shafts and when i made the pin. I pressed the to together with my press and used it to hold preasure when i welded the two shafts. If that makes sense..
