Workshop
The Mad Scientist
Kick starter
Topic: Kick starter (Read 7026 times)
bill1984
Kick starter
July 29, 2013, 09:15:10 PM »
This my version of dd kicker shaft , much cheaper lol.. I took 2 shafts and pined the 2 together and welded them.[attach=config]1099[/attach][attach=config]1100[/attach] so far so good. I got 4 weekeds of racing on it..
Polonda
Kick starter
July 29, 2013, 09:17:57 PM »
Nice! And with a good weld job it will never break. This is the kind of stuff I'm all about.
Morse250r
Kick starter
July 29, 2013, 09:22:17 PM »
Direct drive used to modify stock kickers and they wod snap over time that's why they had the new lengthed ones made now. But most have more time then money but as long as it doesn't brake a leg!
88 rb racing duner
Trx 70\'s
Atc 125
atv fan 28
Kick starter
July 29, 2013, 09:22:38 PM »
nice job!!!!
jcs003
Total likes: 44
Kick starter
July 30, 2013, 07:56:32 AM »
damn good, cant really see where the weld is.
here is a way to strengthen it:
bore a hole in either end that will allow a press fit
press in a high tensile steel rod
press other end on, then weld that sucker together. should never break.
bill1984
Kick starter
August 02, 2013, 09:40:25 PM »
Thanks guys
Farmboy1979
Kick starter
August 09, 2013, 07:30:42 PM »
How did you make sure the shafts were straight?
bill1984
Kick starter
August 12, 2013, 10:04:36 PM »
I used my lathe when i drilled the two shafts and when i made the pin. I pressed the to together with my press and used it to hold preasure when i welded the two shafts. If that makes sense..
Workshop
The Mad Scientist
Kick starter
