Author Topic: Rear brake question  (Read 2789 times)
Offline BigKeeKee
Rear brake question
« on: March 03, 2016, 08:48:20 PM »
when putting a block off plate on the rear brake, is it just remove e brake, an bolt on block off plate? installed block off plate an cant get brakes to bleed now
Offline trx250scar
Rear brake question
« Reply #1 on: March 03, 2016, 09:07:30 PM »
There is an o ring in there that seals were the rod is that the cable mechanism pushes on the piston to engage the parking brake. I bet it is bad. It is pretty small
Rear brake question
« Reply #2 on: March 04, 2016, 05:56:13 AM »
Are you bleeding with a vacuum pump or doing it manually?
