Workshop
Suspension and Chassis
Rear brake question
Topic: Rear brake question (Read 2768 times)
BigKeeKee
Rear brake question
March 03, 2016, 08:48:20 PM »
when putting a block off plate on the rear brake, is it just remove e brake, an bolt on block off plate? installed block off plate an cant get brakes to bleed now
trx250scar
Rear brake question
March 03, 2016, 09:07:30 PM »
There is an o ring in there that seals were the rod is that the cable mechanism pushes on the piston to engage the parking brake. I bet it is bad. It is pretty small
broken1
Total likes: 156
Rear brake question
March 04, 2016, 05:56:13 AM »
Are you bleeding with a vacuum pump or doing it manually?
Workshop
Rear brake question
