Author Topic: Newbie 1989 trx 250r project  (Read 15787 times)
Offline mudbogger
« on: March 13, 2016, 09:13:16 PM »
Hi All. Newbie here to the site, and also to my 1988 trx 250r. A bit of history behind this ride. Purchased years ago by myself for a rider, ebay purchase, had limited knowledge of these particular rides, the ATC 250R I do have much experience with. Bought and after a good hard look decided to take it apart and start over. Well life, work, marriage, etc put the project on hold, but the time has come to get it rolling again.
When I first purchased, the engine needed a rebuild, compression was not what seller stated and to be honest did not bother me, I rebuild engines all the time and if I can't my engine builder is more then happy to do for me:beguiled: so off the frame it was. Stripped it down to a bare frame, cataloged what I did not have, and had, purchased items I wanted to upgrade too, and then it sat on the shelf for all these years.
Moving forward, here is the current status. Frame had a Pumashine gusset kit welded in it. I have purchased Lonestar +2 a arms with tie rods, +2 OR +4 Lonestar steering shaft, Lonestar anti vibe, Laeger swinger, rear hubs,anti lock nut, sprocket hub, the works in the back.
CURRENTLY have engine in the frame for mock up purposes, the engine I plan on running is being rebuilt currently, nothing out of ordinary, no ECR jug or anything, just one bore up on jug, OEM Honda piston, Boyesen Rad valve, LRD expansion chamber with silencer, basic stuff.
What I am doing currently is mock up to make sure I have everything for the project, after mock up is complete I will tear it down and send what needs to go to powder coating BUT i MIGHT PAINT the stuff as well, powder I have done for years, love it but also I hate it. Have time to figure that out.
Here is a couple pictures
« Last Edit: April 09, 2016, 06:58:30 PM by mudbogger »
Offline mudbogger
« Reply #1 on: March 17, 2016, 08:03:46 PM »
Purchased a set of spindles of a member here. Weighting purchase of rad valve of just go stock reed cage as I trail ride most of the time anyway, long wide open runs not really in the areas I ride. Have all the rear components, Axis front shocks are goin g to be sent out for re valving. Stock rear is as well something I need to think about just a service as the seals are shot in it, or a purchase of a used aftermarket from a source. Any information of shocks?
Offline mandom250r
« Reply #2 on: March 18, 2016, 01:07:07 AM »
Definitely sounds like a project going on here... good start though
« Reply #3 on: March 18, 2016, 01:17:53 AM »
Get that beast together, riding time is here!
Offline mudbogger
« Reply #4 on: March 19, 2016, 03:59:38 PM »
Looking into handlebars, and also replacing the rear shock internals as it was leaking badly. Took shock apart today, threaded tie rods and ends onto +2 new tie rods, I am not going to put the rear bearing and such together till after I get the main items back from powder after I dis assemble the TRX.
Any opinions about handlebars is welcomed, I am 6-4 225 pounds with long arms, have a anti vibe already on the stem.
Offline mudbogger
« Reply #5 on: March 19, 2016, 04:49:16 PM »
Question, on the bottom of the steering stem, is there supposed to be a flat washer under the nut to hold the stem into the bearing? Mine does not have anything, all that was there was the bearing.
« Reply #6 on: March 19, 2016, 05:31:58 PM »
I have a washer an nut on my stem. At your height  i would  think a low bend would  be fine , I'm 5'8 an low bend  work's  for  me.
Offline mudbogger
« Reply #7 on: March 19, 2016, 05:44:58 PM »
Thanks, I figured as much but wanted to check. Everything on this thing is missing, or replaced with the wrong item. Shot you a text:05.18-flustered:
« Reply #8 on: March 19, 2016, 05:49:10 PM »
Looks like a fun project. Hearing it run & being able to ride it for the first time will make the wait worth it.
Offline mudbogger
« Reply #10 on: March 19, 2016, 07:48:03 PM »
http://www.ebay.com/itm/NEW-Aluminum-Airbox-Air-Box-Intake-Honda-TRX250R-TRX-250R-CFM-Performance-/152014684772?hash=item2364c80264:g:oU4AAOSwezVWy5TM&vxp=mtr
Air box I purchased some time ago as well to replace the stock one. I may just go back to the old school air box, thinking it out
Offline jwraymond6
« Reply #11 on: March 19, 2016, 08:01:25 PM »
Quote from: mudbogger;65671
http://www.ebay.com/itm/Pro-Taper-Contour-Red-Fat-Handlebar-Windham-RM-Mid-Bend-1-1-8-28-6mm-Bar-Pad-/381574343599?hash=item58d79a6baf:g:nhgAAOSwiwVWR5hV&vxp=mtr
Will these bars work with the Lonestar 1 1/8 clamp I have?
They should as long as there 1 1/8 bar like your clamp
Offline mudbogger
« Reply #12 on: March 20, 2016, 02:49:33 PM »
Is this swinger a "no link" swinger?
Offline mudbogger
« Reply #13 on: April 09, 2016, 07:03:52 PM »
Forget the swinger question, I figured it out. I wanted to ask the group several questions- running a rad valve intake what carb air box combo are you guys using with it? I have the stock reed cage and carb combo dry fitted on the ride with all the stock rubber intakes and I am way off on the carb to jug side intake, now my garage is not heated and currently the weather is like 30 degrees so the rubber is not going to flex like it should, but it is over an inch out. Is anybody running a spacer plate with there rad valves? or stock intakes?
Also, where are you guys mounting the rese's on the front of your rides please? Any pictures?Thanks!
« Reply #14 on: April 09, 2016, 07:44:11 PM »
i have run a reed spacer on stock reeds to make it fit . sometimes ya gotta leave the air box loose an push it to meet the rear of the carb.
