Author Topic: Aftermarket brakes  (Read 3529 times)
Offline Grande huevos
Aftermarket brakes
« on: March 19, 2016, 03:40:02 PM »
I have a front caliper  that's in bad shape and it catches every rotation... What are you guys doing for a aftermarket brake upgrade ?
« Last Edit: March 19, 2016, 04:42:47 PM by Grande huevos »
Aftermarket brakes
« Reply #1 on: March 19, 2016, 09:19:38 PM »
Its not a warped  rotor  ?
Aftermarket brakes
« Reply #2 on: March 19, 2016, 09:56:50 PM »
Front brake options:
option 1. inspect and rebuild all components. as Rich stated check the rotor (250R oem brakes)
option 2. 400ex or 450r spindles and brakes
option 3. 400ex spindles with YFZ calipers
Aftermarket brakes
« Reply #3 on: March 19, 2016, 10:01:54 PM »
I have option #2 complete  400ex  hubs, spindles,calipers to master cylinder,  rotors
Aftermarket brakes
« Reply #4 on: March 19, 2016, 11:36:45 PM »
it could be slightly  But the caliper is trashed too. The pins are stuck so the pad has a hard time sliding and the ceramic cushions stick to the pads and do not stay in the holes. The wheel has a ton of drag and when you pull the brake both wheels stop but the one doesn't always release right away.
Does anynody have a used one in working order for a fair price? I already have good pads that part doesn't matter
Offline Aceman
Aftermarket brakes
« Reply #5 on: March 19, 2016, 11:41:47 PM »
I have stock calipers that I fixed up and cleaned out years ago, and they still work better than a new quad.  The trick is to make sure the pins that the pads ride on are spotless, I hit mine with a wire wheel to knock the rust and dirt off.  Also, if you pop the pistons out of the calipers and take a small pick and pop the o-rings out that the pistons seal against, you can get in there with a pick and clean any gunk out that's building up behind the o-rings.  If those o-rings have gunk behind them, it's going to make them squeeze the piston tighter, and the pistons won't want to retract and your brakes will always want to drag.
Almost forgot to mention, I ordered up some Russell Speed Bleeders years ago to help bleed the brakes.  They were a little expensive, but it was super easy to bleed the brakes.
Arens Axis XC 310R
Houser Axis Duner CT350PV
Aftermarket brakes
« Reply #6 on: March 20, 2016, 02:30:15 AM »
I have   some calipers  pm me .
