Author Topic: Anyone have a CRF450 dirt bike?  (Read 3845 times)
« on: April 17, 2016, 09:13:30 PM »
Looking to use a CRF450 dirt bike rear brake master cylinder so if someone has one and can measure the distance between the center of the bolt holes, that would be much appreciated.  Thanks in advance.
« Reply #1 on: April 18, 2016, 01:27:35 AM »
[MENTION=540]JesseA420[/MENTION]
« Reply #2 on: April 18, 2016, 06:59:40 AM »
crf master bolt spacing is 49mm :)
« Reply #3 on: April 18, 2016, 01:44:00 PM »
Quote from: JesseA420;66690
Thank you sir!  I'm considering (what I assume to be a late 80's - early 90's cr250 master cylinder) that is on an aftermarket frame.  It measured about 50mm so I assume the crf450 will fit.
« Reply #4 on: April 18, 2016, 03:16:11 PM »
wallow out the holes a smidge and it should bolt right up!
