Author Topic: Axle splines  (Read 9761 times)
Offline muthahucker
Axle splines
« on: May 20, 2016, 01:59:01 AM »
Does anyone know what the axle spline count is on a lonestar axle and a durablue axle on the drive side?
I have an aftermarket axle that I got in a pile of parts that I thought was a lonestar axle.  The brake side used all stock hardware, so I bought a Lonestar drive sprocket thinking that it would fit.  I just got it and found that the axle has 39 splines and the sprocket has 40 splines... I guess what im asking is if anyone has a durablue axle that they know what the spline count is on it.
Its possible I guessed wrong and have a durablue axle, but I thought they wouldn't allow the use of the stock break side sprocket.
Offline Big_Mike
Axle splines
« Reply #1 on: May 20, 2016, 11:58:20 AM »
I'm pretty sure the axle hubs are 25 spline LSR and Durablue and the sprocket hub for the LSR is 39 spline.  Not sure on the Durablue?
Axle splines
« Reply #2 on: May 20, 2016, 12:51:00 PM »
I have 4 different axles an the brake side is all the same. I will go count the splines on my durablue in a lil bit
Axle splines
« Reply #3 on: May 20, 2016, 01:33:00 PM »
I have a Dura-Blue sprocket and am using the STOCK Brake Side Hub....so maybe it's an ATC Axle instead of a TRX ???
You are having trouble with the BRAKE DISK HUB right ?
Mine has 24 splines on the SPROCKET HUB (Left side).... I'll count my Brake Hub tonight. I believe it's 39.....but I will confirm.
« Last Edit: May 20, 2016, 01:48:50 PM by Langbolt »
Axle splines
« Reply #4 on: May 20, 2016, 04:10:36 PM »
24 sprocket side on the brake side i would need to remove the brake hub to count ,this is a durablue. The atc axle is the same except 85 which the diameter where the bearings ride,but the spline count is the same for sprocket hub and brake hub. I could be reading your post wrong but what side are you having a problem with ? It says the brake side fits correct ?
Offline muthahucker
Axle splines
« Reply #5 on: May 20, 2016, 08:48:39 PM »
Brake side has all OEM parts on it that fit fine... Its the drive sprocket side that I'm having problems with.. The axle is an unknown make.. It has 39 splines on the drive sprocket side.  I got a Lonestar drive sprocket thinking it would fit, but it has 40 splines... I'm guessing that  it is possibly a durablue axle and I would need to get a drive sprocket from them.
Axle splines
« Reply #6 on: May 20, 2016, 10:31:15 PM »
The drive side is 24
Axle splines
« Reply #7 on: May 22, 2016, 02:19:06 AM »
I just counted a rpm axle an both sides are 39
Axle splines
« Reply #8 on: May 23, 2016, 08:11:56 PM »
Durablue has 24 Splines on the Sprocket side & 39 on the Brake side.
If you have 39 on BOTH sides then , Like thesmith87250r said....you have a RPM Axle.....and will need a RPM Sprocket hub.
Axle splines
« Reply #9 on: May 24, 2016, 10:38:27 AM »
https://www.team-rpm.com/honda-atv-parts/trx-250r-honda-atv-parts/sprocket-hubs.html
http://www.team-rpm.com
 I found a pic on their Facebook page....Does your Axle look like this ?
« Last Edit: May 24, 2016, 12:53:14 PM by Langbolt »
Offline muthahucker
Axle splines
« Reply #10 on: May 25, 2016, 01:57:41 PM »
Looks very similar to that.  I'm pretty sure its not a lonestar axle.  There are no markings on the axle shaft that I can find anywhere.  Any pics of lonestar I have seen has a flat spot in the middle of the axle with its model info on it.
Axle splines
« Reply #11 on: May 25, 2016, 08:27:46 PM »
Rpm will have the flat spot in the middle   model an serial # I'll take a pic if mine  an post it.
Axle splines
« Reply #12 on: May 26, 2016, 11:27:30 AM »
thats good news tho, rpm > durablue
lol.
Axle splines
« Reply #13 on: May 26, 2016, 01:19:08 PM »
sorry thought their was a flat spot on the rpm i was wrong
Offline muthahucker
Axle splines
« Reply #14 on: June 18, 2016, 10:03:42 AM »
Got it all worked out and reinstalled in the 85 ATC now.  Lonestar sprocket worked, still no idea exactly what make of axle this is.
Thanks
