Author Topic: Chain guide problem  (Read 19774 times)
Offline Troy
Chain guide problem
« on: June 02, 2016, 10:45:26 PM »
OK so I got my new lonestar swingarm on today, and bolted on my new TM chain guide, but it doesn't line up with the sprocket.  Anyone else had this problem?  Thinking lonestar might have screwed up on the mount.  Here's some pics
Chain guide problem
« Reply #1 on: June 02, 2016, 10:53:16 PM »
I have a lonestar an don't have that problem.  I can get some measurements over the weekend to compare.
Offline Troy
Chain guide problem
« Reply #2 on: June 02, 2016, 11:05:34 PM »
That would be great thanks
Chain guide problem
« Reply #3 on: June 03, 2016, 01:01:21 AM »
Quote from: Troy;68016
Troy what kind of carrier is that?
Offline Troy
Chain guide problem
« Reply #4 on: June 03, 2016, 01:30:38 AM »
It's a rad double row
Chain guide problem
« Reply #5 on: June 03, 2016, 09:16:48 AM »
Is that by chance a new LSR axle as well? I might be crazy, but it looks like your sprocket hub is sitting further into the carrier than it should be. Some axles have an aluminum sprocket hub, but a steel insert that actually rides in the carrier seal. I wondered if it might be missing.
Offline Troy
Chain guide problem
« Reply #6 on: June 03, 2016, 09:45:21 AM »
The axle is 12 or 13 years old, I ran a straight edge on the sprocket to the front sprocket and going by that the axle needs to slide in farther.  There's probably a half inch difference
Chain guide problem
« Reply #7 on: June 03, 2016, 10:33:08 AM »
Quote from: Troy;68034
Is the sprocket in line with the counter shaft sprocket?
Offline Troy
Chain guide problem
« Reply #8 on: June 03, 2016, 10:50:05 AM »
No it's off a bit
Chain guide problem
« Reply #9 on: June 03, 2016, 10:55:11 AM »
Quote from: Troy;68036
No it's off a bit
Does your brake rotor line up correctly with your caliper?
Offline Troy
Chain guide problem
« Reply #10 on: June 03, 2016, 11:29:33 AM »
Yep lines up perfect
Chain guide problem
« Reply #11 on: June 03, 2016, 03:01:11 PM »
Have you given a call to Lonestar yet? No one is above reproach. It is possible then that the swingarm itself is bad. And bearings in carrier is still good? Bearing surface on axle is still good?
Chain guide problem
« Reply #12 on: June 03, 2016, 03:01:56 PM »
I believe [MENTION=29]oldschoolr[/MENTION] is running a LSR swinger.
Offline Troy
Chain guide problem
« Reply #13 on: June 03, 2016, 04:47:32 PM »
It all seems good, going to call lsr
Offline Troy
Chain guide problem
« Reply #14 on: June 03, 2016, 04:56:54 PM »
Sent them some pics, we will see what they say
