Author Topic: Idle screw? 39mm keihin pwk  (Read 4819 times)
Offline yugyagz
« on: July 04, 2016, 07:57:51 AM »
I recently got bike from guy at work. For starters he told me this was stock carb and it obviously isn't. Question is, isn't there supposed to be an idle screw here? Where this hole is? Or are these like stock carb and you have choke/idle knob.
Offline jwraymond6
« Reply #1 on: July 04, 2016, 08:16:37 AM »
The open hole right above where it says keihin is where it's supposed to be I believe
Offline The_Steve_Man
« Reply #2 on: July 04, 2016, 10:10:26 AM »
That is were the idle screw goes. You can get onto from Jetsrus
Offline yugyagz
« Reply #3 on: July 04, 2016, 10:18:59 AM »
Thank you guys. Just bought one on eBay. Prolly paid way to much lol I'm gonna look on that site right now
Offline yugyagz
« Reply #4 on: July 04, 2016, 10:22:51 AM »
Ok. So there's a plastic screw replacement and a brass? It looks like it said brass is for non chrome slides? Im not at all rounded with any of this. If I ordered the brass will it not work? My slide looks chrome
Offline yugyagz
« Reply #5 on: July 04, 2016, 10:46:53 AM »
There's also a spring for the plastic screw and but for brass it looks like. I bought brass screw and spring not knowing lol. Can I still use them? Dont want to damage anything
« Reply #6 on: July 04, 2016, 12:48:44 PM »
You should be fine with a brass screw unless you have a real stiff throttle spring & let it slam shut from full throttle all the time.
Offline Piney0
« Reply #7 on: July 04, 2016, 02:52:54 PM »
The slides with a chrome covering 'should' get a plastic screw.  the brass / alumunum ones can chip the chrome on the slide.  That being said, the plastic PWK idle screws are known to be easy to break.
Offline yugyagz
« Reply #8 on: July 04, 2016, 03:43:11 PM »
So I ordered the brass one.sounds like I "should" be okay as long as I'm not slamming throttle
