Author Topic: Brake piston fiber insert  (Read 12603 times)
Re: Brake piston fiber insert
« Reply #15 on: January 31, 2020, 08:51:09 AM »
Hey Joe I bought a couple sets of  those a few years ago on ebay. The seller was   cyclesrus-greatparts   and has a shop down by chippewa lake, CyclesRus if you want to go direct. Maybe he can still get some.
Bill
Bill, I went to the shop.... nothing available
« Reply #16 on: January 31, 2020, 01:57:17 PM »
The 2 Piston rebuild kits that were available on AMAZON.....are no longer available..... :(
Maybe there are pistons from the CFR nissin calipers that will work ???
Offline 4WHLr
« Reply #17 on: January 31, 2020, 06:17:37 PM »
Well, That's a couple of bummers there.
Has anybody ever measured how deep the front pistons are compared to the rear, since they use the same diameter and part numbers for seals?
 I may do some digging this weekend.
Ive seen them with the e-brake pin/port plugged and have two of the non e-brake pistons in them too  :o which is what made me wonder about the front pistons.
On a side note, I have at least one used  fiber disc if anybody needs or wants it, you can have it.
1986 TRX275R PC2000
« Reply #18 on: January 31, 2020, 09:36:02 PM »
Would you mind measuring the diameter & thickness of that fiber disc & posting it here? Or let me borrow it so I can make some copies? Thank you
« Last Edit: January 31, 2020, 09:38:28 PM by broken1 »
Offline 4WHLr
« Reply #19 on: February 01, 2020, 12:08:17 AM »
It is right around 3mm thick and just under 22mm ( 21.95 - 22mm ) in diameter
to fit in the piston which is a 22mm by 2mm deep recess
1986 TRX275R PC2000
« Reply #20 on: February 01, 2020, 12:43:49 PM »
Perfect thank you 4WHLr.
