Author Topic: HELP rebuilding Gibson a arms  (Read 4913 times)
Offline Action69
« on: November 29, 2017, 05:54:55 PM »
Hello I'm currently rebuilding a set of Gibson a arms I'm unsure of how to set the clip that goes below the bearing.It looks like it could possibly turn in but I don't want to force it or bend it being I don't have any spares.im going to attach two pictures.thank you for any help.
Re: HELP rebuilding Gibson a arms
« Reply #1 on: November 30, 2017, 02:21:29 AM »
hey Action69, I did not know Gibson arms were that way....what you have is a Spiral Retaining Ring.  Installation is easy.....easier to check out the video than for me to type....
 https://www.youtube.com/watch?v=dvWY1s0zmHw
Spares can be purchased/sourced from your local bearing distributor, Grainger or McMaster Carr.
Offline Action69
« Reply #2 on: November 30, 2017, 08:45:47 AM »
Thank you for the response and the link.
Offline Action69
« Reply #3 on: December 01, 2017, 12:28:56 AM »
Those clips came with the new bearings I bought for the gibsons from k&k atv .im also currently rebuilding a set of Walsh a arms and they use the same style bearings with c clips.if these spherical clips give me a tough Time going in do you think c clips would work?thanks for any input.
« Reply #4 on: December 01, 2017, 01:49:10 AM »
i would think a snap ring would work you would need the correct thickness imo.  just make sure you install what ya have correctly .
Offline Action69
« Reply #5 on: December 01, 2017, 09:12:30 AM »
Ok thanks.ill see if I can find a match.
« Reply #6 on: December 01, 2017, 06:37:49 PM »
I have a set of a-arms in a parts lot that look home made & they have the same bearing end your gibsons have. They used a c-clip on them & they were tack welded in because it looks like they were trying to push out. It makes me think Gibson uses the spherical retaining ring to prevent them from pushing out & being a full 360 degree clip instead of having an open end like a c-clip it seems like they would be stronger as well. Just my .02
« Last Edit: December 01, 2017, 06:39:32 PM by broken1 »
Offline Action69
« Reply #7 on: December 01, 2017, 08:13:50 PM »
Thanks Kevin.im going to try and turn them in like in the video croat1. Linked up.its been a while hope all is well.
