Author Topic: Brake pedal seal  (Read 7419 times)
Brake pedal seal
« on: December 31, 2017, 01:28:38 AM »
the trx250R brake pedal seal is discontinued (91206-965-003).  A part number that works is Honda number 91303-KA3-732
Re: Brake pedal seal
« Reply #1 on: December 31, 2017, 03:15:52 AM »
Thanks Joe. I was going to take one into a bearing shop to try & find a match but you just made it easy.
« Reply #2 on: December 31, 2017, 05:41:48 PM »
I went to the local hardware store and bought O-rings (2 plus 2 spares) that fit snug into the grooves, and are also a snug fit on the pivot. With a little grease they slide/seal good. I also drilled the brake pedal for a grease fitting, adding grease and pushing out any debris is now simple with out disassembly, and that was my goal. Look at any of these and you will find the pivot is rusty, not mine.
desertR
Thanks for posting your set up.  I think that would be the best way to go.
Offline DOUGLAS
« Reply #3 on: January 02, 2018, 07:39:32 PM »
nice idea on the grease fitting
LED 363 87 stock frame
