Author Topic: Wanted  (Read 7750 times)
Wanted
« on: February 17, 2019, 01:15:50 AM »
In desperate need of a NOS 88/89 right side case
88/89 foot peg mounting hardware
87-89 stock cylinder and head (NOS).
Thanks
Offline Action69
Re: Wanted
« Reply #1 on: February 17, 2019, 10:53:44 AM »
What. Exactly do you need in terms of foot peg mount
 hardware.?are you looking for nos or. Usable Hardware
Re: Wanted
« Reply #2 on: February 20, 2019, 12:05:38 PM »
Steve, I need the pins and springs. NOS would be great but nice used is ok also.
Offline Action69
Re: Wanted
« Reply #3 on: February 20, 2019, 08:00:26 PM »
Ok joe I may have them I’ll check when I go to my garage..they’re not nos..
Offline meathead
Re: Wanted
« Reply #4 on: February 25, 2019, 01:54:39 AM »
Actually 85 to 89 right side cases are the same The whole engine is the same. The only difference is 85 & 86 are short rod engines. 87 to 89 are long  rod engines. There are slight differences in different year heads. as a matter of fact i have an extra cylinder and head
« Last Edit: February 25, 2019, 01:58:50 AM by meathead »
Re: Wanted
« Reply #5 on: February 25, 2019, 01:22:58 PM »
Mostly true. If you look at the very front of the engine where the mounting bolt goes through the cases there is a difference in appearance.  If you mix and match cases you will notice the difference.  The earlier cases had more of the bolt exposed than the later cases. Thanks Loren
« Last Edit: February 25, 2019, 01:34:56 PM by The norm »
Re: Wanted
« Reply #6 on: February 25, 2019, 01:28:30 PM »
I think you have that swapped around Loren. Early cases had less of an opening. 88-9 had the bigger opening
Re: Wanted
« Reply #7 on: February 25, 2019, 01:34:17 PM »
I do have it swapped around.  Thanks Gene lol
Re: Wanted
« Reply #8 on: February 25, 2019, 02:06:16 PM »
Keep in mind the color difference also. The right side case I’m looking for is for a buddy that is doing a complete NOS build.
@meathead, the cylinder and head that you mentioned...new?
Offline 2Nubs
Re: Wanted
« Reply #9 on: February 25, 2019, 03:17:16 PM »
I was really confused how my trike cases have the V style opening lol. I had also read elsewhere that the V style was late model. Thanks for clarifying Gene.
‘86 330
Re: Wanted
« Reply #10 on: February 25, 2019, 08:05:59 PM »
There's more subtle differences between all the years than most realize.
Re: Wanted
« Reply #11 on: February 25, 2019, 08:19:20 PM »
Absolutely
Offline meathead
Re: Wanted
« Reply #12 on: February 26, 2019, 12:05:25 AM »
CROAT 1 No its not new, but i'm pretty sure it has a stock bore. You probably want a matched set of cases.
« Last Edit: February 26, 2019, 12:08:46 AM by meathead »
Re: Wanted
« Reply #13 on: February 26, 2019, 01:14:01 AM »
Honda didn't even sell them as sets
Offline meathead
Re: Wanted
« Reply #14 on: February 26, 2019, 02:01:39 AM »
I stand corrected. Sorry for my ignorance.
