Author Topic: Ignition wire grommet  (Read 6218 times)
« on: July 20, 2019, 10:17:49 PM »
Hey fellas, I just picked up my 391 from hybrid engineering and I had Pete install a pvl ignition. The wires for the pvl don't have a grommet and I obviously do not want to run without one. So help me out here. What is the hot setup for sealing the hole in the case? Thanks Loren
Re: Ignition wire grommet
« Reply #1 on: July 21, 2019, 01:06:45 AM »
I would think a normal grommet with some good old silicone would work
« Reply #2 on: July 21, 2019, 04:14:04 AM »
A .50 grommet not included? What the what? As Gene said. McMaster-Carr should have what you need.
Online croat1
« Reply #3 on: July 21, 2019, 10:57:36 AM »
As Gene stated...do you have any junk stators?  Call and see if Ricky Stator (or the other aftermarket electrical places) will sell a grommet.
« Reply #4 on: July 21, 2019, 01:30:54 PM »
I have a junk stator just not sure if I can cut it off without destroying it. I will give it a shot because I can't wait to see what this engine will do!
