Author Topic: Trying to decide on what 350cc kit to run.  (Read 13915 times)
Offline Hutchracer
« on: November 04, 2019, 04:11:00 PM »
So I have an 86 TRX250R and I am looking to do a 350cc Big Bore on it.
I am considering the BDT Pro-X w/the BDT Pro Porting & Flow.
I am basically building this for the dunes and would like to have enough power to drag with the boys.
Just curious if any of you guys have ran this set up. I see the Pro-X kits have better reviews than the ESR kits. I am wanting make sure I spend my $ getting the right kit. I've seen that CT sells a kit too but haven't seen much info in comparison to the BDT kit.
What do you guys think?
Re: Trying to decide on what 350cc kit to run.
« Reply #1 on: November 04, 2019, 05:24:56 PM »
You wont see hardly any pro-x kits chosen over esr kits today. I would look into the esr ceo kits.
« Reply #2 on: November 04, 2019, 05:33:38 PM »
CT racing Prox-X cylinders are not available (new) at this time.  I’d suggest a CP industries cylinder if you have the funds.  ESR cylinders are a great buy.  Get the cylinder ported by Selvey, LED, BHP, Hybrid or Jerry Hall.
What engines are the guys running that you are racing against?
« Reply #3 on: November 04, 2019, 06:48:42 PM »
I think you should absolutely stay away from BDT! I had a ESR cylinder ported by BDT and it was nothing but trouble. I had Hybrid engineering work it over and now it is a monster. I recently had Hybrid build a 390 for me and it is fantastic. I went with the ESR cylinder again and can't complain.
« Reply #4 on: November 04, 2019, 07:27:56 PM »
I agree with Joe on this. Plus why pay extra to a guy that charges for services he does not perform. Stay with builders that don't have a cload over them.
Offline Hutchracer
« Reply #5 on: November 04, 2019, 07:49:58 PM »
I was also looking at the LED/ESR kit too. The ones where Arlen @ LED takes the ESR head and does work on that.
Yeah I just want to make sure that I am happy with the end result of the build.
« Reply #6 on: November 04, 2019, 07:59:15 PM »
What part of the country are you located
Offline Hutchracer
« Reply #7 on: November 04, 2019, 08:03:16 PM »
I live in the PNW just south of Seattle
« Reply #8 on: November 04, 2019, 08:08:20 PM »
Ok I'm in Washington too. I would definitely look at Arlan(led) or Pete(hybrid engineering). They are both in pnw. So easy to get motor to them.
« Reply #9 on: November 04, 2019, 08:11:21 PM »
You came to the right forum...lots of PNW guys here.  Not me though. I’m from Ohio. I did make it out to Winchester Bay for our ORG meet up ride.
Offline Hutchracer
« Reply #10 on: November 04, 2019, 08:16:49 PM »
Yeah I was looking at LED prior because I know the stuff he builds is always good.
Does Hybrid Engineering have a website or anything? I did a quick search on my phone and it just brings up posts on forums but no website info.
Unless I'm totally over looking it.
Offline Hutchracer
« Reply #11 on: November 04, 2019, 08:32:45 PM »
I just picked the quad up last week from my brother.
It's an 86 with a few things done to it. I got it with Silver Maier Plastics, a Laeger's Anti-Vibe Stem, a set of new extended A-Arms that aren't installed yet, a pipe and silencer which have no markings on, and a basic K&N cone filter in the air box. Oh yeah he also gave me a brand new still sealed in the box Hot Rods complete bottom end kit for it.
I pulled the carb to clean it and check the Reed Cage and noticed that the piston had a crack in the bottom of the skirt.
I already had plans to build it but I figured I'd do the biggest displacement I can where I can still use the Brand New bottom end kit I got.
« Reply #12 on: November 04, 2019, 08:56:53 PM »
Pete is in washugal( spelling). No he doesn't have a website or anything. He does do top notch work. He built my puma motor this year. I'm very happy with his work. A friend just had one done by Arlan. It is a good motor too. I would think Pete would be able to get one done for you quicker. Being a bit smaller then led
Offline Hutchracer
« Reply #13 on: November 04, 2019, 09:18:40 PM »
I'm trying to figure out if should end up just ordering up a 350cc kit from ESR and then just sending it out with the cases to Hybrid Engineering now.
Does he do porting work also? I've heard that ESR doesn't exactly do a proper "Porting" more or less just cleans up the ports.
I want to get a nicely ported motor so that it is making some good HP. I also know with a 350 I will need to have the cases done to match the cylinder.
I wish there was some way to get ahold of Hybrid Engineering to get pricing and go over what I am thinking on my motor.
Since you have had a motor done by him do you know of how to contact them?
Washougal is a couple of hours away from my house. So taking him the motor is no issue but I want to be able to talk pricing first.
« Reply #14 on: November 04, 2019, 09:25:34 PM »
Yes Pete does the porting in house
