Author Topic: Exhaust Hi Temp Foil  (Read 5587 times)
« on: November 18, 2019, 10:32:13 PM »
Anybody use the stick-on high temp foil tape on their inner fenders where the stinger goes?  Fitment is pretty tight there on the 443 with the Cascade CSFX silencer, and thinking of putting some foil tape on the plastic in this section but have no experience with it.  Anybody use it?  Any recommendations or things to stay away from?
Re: Exhaust Hi Temp Foil
« Reply #1 on: November 19, 2019, 06:12:50 PM »
iv been thinking about this also. come time i put my new Full Bores on if that guy melts im going to be pissed.
« Reply #2 on: November 19, 2019, 09:42:39 PM »
I used the aluminum back sound deadening for a couple years on one set of plastics. Held up good, kinda slide around a little.
« Reply #3 on: November 24, 2019, 11:38:38 AM »
Metal tape that hvac people use works great.  I use it on fenders and the rad hose near the pipe.
« Reply #4 on: November 25, 2019, 01:10:28 PM »
Thanks guys - was looking at this https://www.amazon.com/3M-High-Temperature-Flue-15-Foot/dp/B00004Z4DS - thoughts on whether it would do the trick?
« Reply #5 on: November 25, 2019, 08:21:06 PM »
Shoot i have that stuff in stock at work lol looks like im good
« Reply #7 on: November 26, 2019, 05:19:24 PM »
This is what I used.... I know it's not exactly what you are looking for..
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.amazon.com/Design-Engineering-010420-Heat-Sheath/dp/B001HYSCB2&ved=2ahUKEwips_bS94bmAhVoJzQIHdjyBWcQFjAAegQIAxAB&usg=AOvVaw3CTOmQ313OF0o54bGRiKyt
Thanks Loren.  Looks similar to the stuff Cascade would sell/use on their stingers.  I've heard it traps moisture though, have you had any issues like that?
« Reply #8 on: November 26, 2019, 06:07:56 PM »
Not so much as I can tell after one ride with it on. I will have to check it out and see
« Reply #9 on: November 26, 2019, 07:07:40 PM »
did you put it on your stinger or stick it to the inner fender?
« Reply #10 on: November 26, 2019, 08:11:16 PM »
Stinger
« Reply #11 on: November 26, 2019, 09:41:19 PM »
Cutting it on the seam & adding hi temp velcro could fix that if there's hi-temp velcro.
« Reply #12 on: November 27, 2019, 12:20:12 AM »
The man with all the answers! haha.
And thanks guys for the feedback
