Author Topic: 01 cr 250r ignition  (Read 6891 times)
Offline dp250r
01 cr 250r ignition
« on: May 12, 2020, 09:27:42 AM »
Wanted 01 cr 250r ignition stator, flywheel, cdi ,coil wire harness. Or 85 cr500 cdi.
Offline dp250r
Re: 01 cr 250r ignition
« Reply #1 on: December 08, 2021, 03:20:57 PM »
Anyone have a 95 or newer cr250r ignition flywheel, stator, cdi and coil.From my research just about any cr250r ignition will also work in a cr 500r.
« Reply #2 on: December 09, 2021, 04:00:33 AM »
Offline dp250r
« Reply #3 on: December 09, 2021, 03:43:07 PM »
I haven't seen this one before.Thanks I have enough saved for it.Alot for a used system but I'm sure if I sell the motor with the updated clutch cover and this ignition system I would be money ahead.
Offline dp250r
« Reply #4 on: February 11, 2022, 10:18:14 AM »
I found an oem 85 cr500 cdi,coil and kill switch on ebay got it for about 175 shipped.It works well I hooked it up to the motor yesterday and it has good spark.
