Author Topic: Flywheel  (Read 4987 times)
Flywheel
« on: November 06, 2020, 04:25:17 PM »
Howdy fellas,  I seem to have a pile of junk flywheels! I could definitely use 1-2. So if you have one and don't need it let me know.
Thanks Loren
Offline Braaaping247
Re: Flywheel
« Reply #1 on: November 10, 2020, 09:25:23 AM »
Are you looking to buy 1? If so i do have 1 available.
Re: Flywheel
« Reply #2 on: November 10, 2020, 12:41:12 PM »
PM me a price if you would.
Loren
Re: Flywheel
« Reply #3 on: December 31, 2020, 01:52:58 AM »
I have to if your still in need sorry it's taking so long to get back 2 you but C
 I've been really busy off now for the  Season do to woRk so privare message me if you still need 1 i actually have 2
Offline desertR
Re: Flywheel
« Reply #4 on: December 31, 2020, 02:50:29 AM »
Couldn't you just tighten the rivets as much as you can, and then TIG weld the hub to the shell. If the shell so really loose, drill out a rivet (or two) to see the location of the shell to the hub, and then weld. Sounds like a simple fix to me.
desertR
Re: Flywheel
« Reply #5 on: December 31, 2020, 11:12:18 AM »
desertR
I weld the flywheel on every engine I work on if I see the rust streaks of the face of the flywheel going radially outward from the rivets.  The rust streaks are an indication that there is some back lash before it can be felt by hand.  Once the rivets get loose enough that you can feel back lash between the hub and flywheel, it is next to impossible to get the flywheel centered before welding. I have welded a few of these where back lash could be felt and they would usually cause engine vibration or sometimes rub the stator.
Re: Flywheel
« Reply #6 on: December 31, 2020, 11:20:51 AM »
desertR
https://www.forums.trx250r.org/index.php/topic,8898.0.html
Re: Flywheel
« Reply #7 on: December 31, 2020, 11:26:44 AM »
The flywheel magnets are broken/loose so not really sure anything can be done. I do have one with rust streaks coming out around the hub.
Jerry, are you seal welding the hub or just laying down a short weld at every rivet? I would assume that a small amount of weld at each rivet is the best procedure.
Loren
Re: Flywheel
« Reply #8 on: December 31, 2020, 11:29:04 AM »
Thanks Joe! I should have read that before I asked Jerry!
Re: Flywheel
« Reply #9 on: January 02, 2021, 01:38:00 PM »
I have 2 of them
