Author Topic: Bottom motor mounts  (Read 4163 times)
Offline evaneyeball
Bottom motor mounts
« on: December 23, 2020, 01:48:17 PM »
So i never really payed attention to my bottom frame mounts and never realized they are oblonged quite a bit and i am wondering if i should make new ones and cut the old ones off then tig weld them back on or is this not a big deal im kind of thinking it is.theres a picture of bolth sides. And i dont have a head mount but could that have caused this. I plan on making one.
LED built 86 trx 350 CEO
81 ATC250r
Re: Bottom motor mounts
« Reply #1 on: December 23, 2020, 01:58:21 PM »
Yes it’s a big deal.....get a Pumashine kit.  Loose motor mount bolts....most likely all of them.
Head stay....some run them some don’t.  I’d for sure run one on a stock frame at least to tie in the upper frame rails
« Last Edit: December 23, 2020, 02:26:10 PM by croat1 »
Offline evaneyeball
« Reply #2 on: December 23, 2020, 02:04:48 PM »
Yeah i want to run a head stay just for added protection and i have been planning on gusseting my frame so i huess ill do it now lol
81 ATC250r
Offline desertR
« Reply #3 on: December 23, 2020, 02:26:02 PM »
You could also just TIG a washer to the outside of the mount, measure the OEM mount thickness, and get a washer that is thicker. Look at your swing arm mounts, Honda did the same thing from the factory, and they work good.
desertR
Offline 2Nubs
« Reply #4 on: December 23, 2020, 05:10:57 PM »
I’ve got a set on my wall of destruction in the garage. They were welded real well with a washer but it will crack eventually. The puma shine set worked excellent for me. Pretty sure they are stainless and slightly thicker.
‘86 330
Offline 2Nubs
« Reply #5 on: December 23, 2020, 05:12:50 PM »
Dang I didn’t read real well that’s the bottom mount obviously. My frame cracked there and one mount was completely missing. Cost me a new frame shipped from Oregon. Gusset kit would be a wise move.
‘86 330
