Author Topic: Engine marking (external)  (Read 9666 times)
« on: January 21, 2021, 08:18:50 PM »
I find this cool so I figured I would share....factory assembly/inspection marking.  On a number of places the engines were paint marked.  Here’s a few for now.  I’ll post the other external locations soon and then I’ll post what I found internally.
Clutch cable mount, actuator arm and left rear cylinder nut.  The cylinder nut is hard to see but the 3 locations I mentioned have a blue paint mark.
« Last Edit: February 04, 2021, 08:55:21 PM by croat1 »
Re: Engine marking
« Reply #1 on: January 21, 2021, 08:20:17 PM »
Exhaust manifold top mount bolt marked in blue.
Re: Engine marking
« Reply #2 on: January 21, 2021, 08:21:27 PM »
Clutch cover bolt and coolant fitting marked in blue.
Re: Engine marking
« Reply #3 on: January 26, 2021, 10:53:19 AM »
More external marking.  Carburetor cap, choke and vent line.
Re: Engine marking
« Reply #4 on: January 26, 2021, 10:56:59 AM »
More carburetor.
Re: Engine marking
« Reply #5 on: January 26, 2021, 10:57:57 AM »
Carburetor again.
Re: Engine marking
« Reply #6 on: January 26, 2021, 10:58:49 AM »
Last carburetor
Re: Engine marking
« Reply #7 on: January 30, 2021, 10:17:47 AM »
The pictures I have already shown are from a 1985 ATC250R.  The following pic is from a 1986 ATC250R.  Blue mark on the case vent T.  I did not see this mark on the 85 atc engines.
« Last Edit: February 04, 2021, 08:06:12 PM by croat1 »
Re: Engine marking
« Reply #8 on: January 30, 2021, 02:16:43 PM »
Joe have you ever seen "A" or "B" markings on cylinders?
I thought the talk about it was BS until I seen it for myself.
I may have a picture. Let me dig around
Re: Engine marking
« Reply #9 on: January 30, 2021, 05:37:33 PM »
1985 atc250r Cylinder intake with a yellow mark.
« Last Edit: January 30, 2021, 05:40:23 PM by croat1 »
Re: Engine marking
« Reply #10 on: January 30, 2021, 05:38:52 PM »
Bottom of intake with some numbers in white.
Re: Engine marking
« Reply #11 on: January 30, 2021, 08:21:12 PM »
Josh, yes I have seen the marking you mentioned.  My 87 cylinder is marked ”B”.  The 85/86 atc250r cylinders do not have the “A” or “B” marking.
Re: Engine marking
« Reply #12 on: January 30, 2021, 09:20:33 PM »
I have some 86 trx cylinders with the A stamp & I think 1 with the B stamp. If I remember right it had something to do with piston/cylinder clearance or something to do with the bore.
Re: Engine marking
« Reply #13 on: February 04, 2021, 08:08:19 PM »
1986 atc250r kicker shaft with a blue mark.
Re: Engine marking
« Reply #14 on: February 04, 2021, 08:10:16 PM »
Once again 1986 atc250r with a blue mark on the end of the kicker shaft.
« Last Edit: February 04, 2021, 08:54:45 PM by croat1 »
